I went to Mazda here in Wellington to order a set of the small plastic
plugs that cover screwheads in the strip of black plastic trim along the
bottom of the windscreen. There are 5 small round ones, and a couple of
slightly larger oval ones. I have a round one missing, and the others are
marked to some degree or another (possibly after a windscreen replacement
a few years ago) all have faded from a black to a sort of powdery
blue-black colour. The small round ones are no problem, they are
ex-stock. The oval ones though are ex Japan only, and only in bags of 10.
At $4 each they're cheap enough, but not if I have to buy 10. Does anyone
else out there want or need to replace those plugs, and want to share the
cost of a bag of 10? Thanks Gary
Windscreen trim plugs
use a black permanent marker instead ?
how many does the trim panel need ? (I'm not near the
MX' at the moment...)
Jeff
the small plastic plugs that cover screwheads in the
strip of black plastic trim along the bottom of the
windscreen.
windscreen replacement a few years ago) all have faded
from a black to a sort of powdery blue-black colour.
only in bags of 10. At $4 each they're cheap enough,
Does anyone else out there want or need to replace
those plugs, and want to share the cost of a bag of
10?
Gary
Jeff
windscreen.
10?
Gary
Jeff
windscreen.
10?
Gary
Jeff
windscreen.
10?
Gary
Hi Hi Jeff, Eeerrr... the answer was in my message...
On Thu, 26 Jun
2003 19:26:20 -0700 (PDT), jeff wrote: how many does the trim panel need
? (I'm not near the MX' at the moment...) --- Gary Morrison
<gm@paradise.net.nz> wrote: --------------------------------- I went to
Mazda here in Wellington to order a set of the small plastic plugs that
cover screwheads in the strip of black plastic trim along the bottom of
the windscreen. There are 5 small round ones, and a couple of slightly
larger oval ones. I have a round one missing, and the others are marked
to some degree or another (possibly after a windscreen replacement a few
years ago) all have faded from a black to a sort of powdery blue-black
colour. The small round ones are no problem, they are ex-stock. The oval
ones though are ex Japan only, and only in bags of 10. At $4 each they're
cheap enough, but not if I have to buy 10. Does anyone else out there
want or need to replace those plugs, and want to share the cost of a bag
Hi Guys,
Without stating the bleeding obvious, a dismantler is surely a cheaper
option. When in Hamilton recently, 'AnyMaz Spares' allowed me to collect
a handful for a few bucks (plus a few other odds &sods). Better than $4
each! There are still plenty in good condition left on the machines
after I left.
Regards,
Dez
after I left.
Regards,
Dez
Hi Guys,
after I left.
Regards,
Dez
after I left.
Regards,
Dez
