Anyone know what size (cc) the injectors from a Familia GTX/GTR are, and whether they will drop into a 1600 mx5? Are there any other cheap options (ie. sourced from the wreckers) for injectors 370cc and bigger that will easily fit.
M@
Injector sizes
Injector sizes
GTXs are 330s, not sure on the impedance. FC-RX7 (high-impedance) injectors are plug'n'play though - 460 and 550cc. Some Toyotas also use the high-impedance Nippondenso injectors - Celica and Supra turbos I think. Mitsubishi GSR/VR4/EVO injectors are meant to work too but they're low-impedance and need ballast resistors. Is this with the Link or stock ECU? cheers,Jeff
Mathew <mathew.avery@deepvideo.com> wrote:Anyone know what size (cc) the injectors from a Familia GTX/GTR are, and whether they will drop into a 1600 mx5? Are there any other cheap options (ie. sourced from the wreckers) for injectors 370cc and bigger that will easily fit.
M@
The New Yahoo! Search - Faster. Easier. Bingo.
M@
Injector sizes
There are quite a few, Supra turbo and non-turbo for example. Go into
solomiata.com (from memory) lots of info there.
Injector sizes
used injectors shouldn't be more than $100-250. Try hanging out on the local amazd/RX7/Toyota/NZPC forums for used stuff . Or ask around at the workshops which do this stuff, they tend to have drawers of them laying around. You could use something like an Apexi S-AFC to trim back the injector signal once you install the bigger injectors...? But then you'd need something else for ignition timing. S-ITC? ...Hmmm. If it were me I'd cheap out and buy a used one from Japan. http://www.skylinesaustralia.com/forums ... 826-1.html The gadget factor of a Link is way higher though!
If you skipped the knock sensor, handcontroller I think the Link is ~$1500 inc. cheers,Jeff (Resident riceboy)
