Hi Y'all,
Amy Jennings here, member number 28514. Not currently on any email list.
Just wondered whether the club has a particular favourite auto electrician or
someone who can fix a seized window motor? Currently been given a price just
for the part which was $300.00 + Any help would be appreciated.
My email is either akl@pacifichorizon.co.nz or ajennings@clear.net.nz
Kind Regards
Amy
Electric Window
Electric Window
Depnding on where you live, give Don at Autoway.services@xtra.co.nz ph (07)
847 5484 (he is in Hamilton) a try or Ross at mx5mart@paradise.net.nz a try.
Electric Window
carbon deposits on the switch mechanism which stopsMake sure its the motor first, my car keeps getting
the motor from running. very easy to clean (JUST DONT
USE SAND PAPE as it scrapes off the protective zinc
coatning of the contact.Just remove the center console
and unplug the switch mech loom.pry the clips of the
mech and it will come apart and the little switch bits
will fall over the place! Clean contacts with contact
cleaner or meths. they go back in very easily. Worth a
go before you fork out $300.
Glenn
Electric Window
I assume those respondents also copied Amy their replys - she won't get them
otherwise as she is not subb'd
