Hmm does anyone know roughly how much im looking at, and has anyone done it themself ?
Laters
Aaron.
CC DHB Secure Mail Server
This email or attachment(s) may contain confidential or legally privileged information intended for the sole use of the addressee(s). Any use, redistribution, disclosure, or reproduction of this message, except as intended, is prohibited. If you received this email in error, please notify the sender and remove all copies of the message, including any attachments. Any views or opinions expressed in this email (unless otherwise stated) may not represent those of Capital and Coast District Health Board. (AC_S001)
[INFO] -- Virus Manager:
No Viruses were detected in this message.
Clutch
Clutch
I'll be doing mine as well shortly, but not doing it myself ! It sounds like a bastard job (and I've done my own shocks, like 3 times so no fear there...). Too much messing around under the car with the hidden PPF and transmission bolts.
Might have a spare 1.8 flywheel and pressure plate available in the near future if anyone's interested (only slips when >6psi
BTW - Autoclutch gives club discounts
Aaron Hart <Aaron.Hart@ccdhb.org.nz> wrote:Hmm does anyone know roughly how much im looking at, and has anyone done it themself ?
Clutch
I did mine myself after having had a shop in Auckland do it, charge me for
all new parts then within 2 months or less strange noises. I figure they
reused the old bearing and pressure plate and only fitted a new clutch disk.
I did it by myself , it was a difficult job , I found the worst part was
getting the box to mate up afterwards(when replacing and I do have a clutch
alignment tool). I am not used to the lifting. What I found that made
getting the box in fairly simple and painless was to use a rope through both
drivers doors, under the car and supporting the tail end, with a knot that
was easily undone to allow the loop to be lengthened as I slid the gearbox
back in. I also used a small trolley jack at the front of the gearbox to
keep the weight off the bearings shaft etc. It was not an easy job, the
aluminium power frame, in my car had razor sharp edges, but it was O.K. (Not
as bad as a mk4 zephyr, or 3L capri). As long as you can bear a few scraped
knuckles maybe you should be o.k. I would recomend having an "Enthusiasts
Shop Manual" along side, and basically follow the procedure outlined in
that.
Good luck if you go for it.
Mike
that.
Mike
