Hi to All,
Anyone know of any Miata forums or similar that deal with engine swaps on Mk1
MX5s? Maybe a V6 of some description?
I dont't really want to go down the the super or turbo path..
I understand that Mazda have 2 distinctive V6 engines from the 90's. The 929
Sentia V6, and the MPV V6 engine ( narrow width)
I've seen pictures of the Mustang powered Miata...not kosher really.
Any ideas?
David Millar
Engine Swaps.
Engine Swaps.
if you go to good old www.miataforum.com and scroll down the list of =
topics, one is dedicated entirely to engine swaps...
There has been discussion in the past of the Mazda K-series six, and =
although some people dont beleive them, Mazda insiders claim that the =
engine is designed to run canted over on an angle to fit transversely =
under bonnets, and that if you try and turn it up-right, as would be =
required for longitudinal mounting, it runs into camshaft or crankshaft =
oiling problems...
oiling problems...
Engine Swaps.
Just out of interest...
Neil Fraser (apparently) is using a 2.5 Mazda V6 in his Fraser racing car.
Due to the nature of his cars, I can't imagine him using the 90 degree
Sentia V6 (physically quite a big engine) - I thought it was the 60 degree
2.5 all alloy FWD based V6 from the TX5/626 driving a RWD set-up. If this
works in a Fraser, it would surely work in an MX5.
Can anyone clarify exactly what set-up he's using?
MD.
MD.
Engine Swaps.
Hi,
I don't know the engine desination but...
Motor: Ford / Mazda alloy 2500cc V6 developing Kw @ 85 rpm. Dry sumped.
Autronic compute.
Gearbox: Quaife 4 speed Dog Box. 2.2:1 low gear.
Final Drive: Modified Sierra Limited Slip Diff Head and axles. 3.9.:1 ratio.
Brakes: Front 4 pot Nissan Skyline Callipers and Willwood 310mm Ventilated
Discs.
Rear 2 pot Nissan and 275mm Rotors.
Front Suspension: Double wishbone with Inboard coils and adjustable shock
absorbers.
Rear Suspension: Fraser De Dion rear axle with trailing arms and coil over
adjustable shock absorbers.
Wheels: 15 x 7 and 7 =" 3-piece Arrow.
Fiberglass: Extremely light vacuum formed in vinyl carbon.
Rollcage: Motorsport NZ Homologated 35mm x 2.5 ex Fraser Cars (factory
tested!)
Instrument Gauges: By Fraser Cars.
Kerb Weight: 575kg
WOW!
DM
Autronic compute.
Discs.
absorbers.
tested!)
Kerb Weight: 575kg
WOW!
DM
