zorruno;
Thanks for the links- your level of tech speak is entirely appropriate for my
understanding.
No brass thingy, no pipes, no ABS, no surprise...
(seems to stop pretty well without it anyway, and one less thing to
potentially break down).
On closer inspection I see I also have a fuse for fog lights, which I don't
have either-I guess they all come pre-wired "just in case".
Phil.
do you have a thingy in the engine bay that looks like this brass thingy
with the pipes coming out of it at the back by the fuse box? I'm pretty
sure roadster & MX5 ABS hydraulic assemblys will be on the passenger side by
the manifold tho.
http://www.miata.net/garage/abs/images/abs_hood.jpg
http://www.miata.net/garage/tsb/images/abs-6.gif
If yes - then you have ABS. I think 91 was the first ABS option (I know of
at least one with ABS)
h+c+z
Re; ABS (do I have ABS on my MX5)
