Swimming Pools
Charles & Morven Lynch
Swimming Pools
Post by Charles & Morven Lynch » Mon Jul 08, 2002 12:22 am
Hi Mark,
I'm not sure what your question is here. If you want a comparison of accuracy
between these two statements, then I would say that Ross is spot on.
The plastic tray is like a rectangular funnel and directs the water down
a tube
through to underneath the car. (I clear mine by putting an piece old
garden hose
down inside the tube and pushing the gunk out.)
Believe it or not, the roof is MEANT to drain into the chassis.
I wouldn't say that the water is supposed to drain into the Chassis. It's
supposed to
go through it and drain onto the street.
standard issue blocking of the door sill drains.
As far as I'm aware there aren't any door sill drains, however there are
pipes about
halfway between the door and the wheel arch underneath each side of the car.
I have heard that some people have drilled holes in their sills to drain
water away,
but the water isn't supposed to be there. I think clearing the drain pipe
regularly prevents this.
Hope this answers your question.
Charles
Charles & Morven Lynch, chicnmo@ihug.co.nz on 8/07/2002
On Fri, 04 Oct 2002 18:47:51 +1200, nmr@iprolink.co.nz wrote:
Return to “2002”
