CAN ANYONE HELP ME WITH HOW TO ADJUST THE DRIVERS DOOR ON MY 92 SO IT CLOSES
TIGHT AND STOPS RATTLING??
THANKS
Allan Barker
DOORS
DOORS
Allan;Adjust the latch (U shaped piece held on with 2 large screws) at the
back of the door shut on the body. You can move it up and down and in and
out to the desired position. Also check that the rubber block at the bottom
of the door shut is is fitting snugly into its mate on the door.Finally
check your latch is tight on the door.Ross.
