Backfiring and exhausts
Nigel Hughes
Post by Nigel Hughes » Wed Mar 13, 2002 6:18 pm
My car is backfiring. It seems to happen changing gear while accelerating,
most often around 4 - 5000rpm. It has been happening for a while, but having
just got my exhaust changed to a more enjoyable timbre, it is much more
noticeable and beginning to disrupt my listening pleasure.
I have an aftermarket header (unknown brand - fitted in Japan) and a cone
type free flow air filter (which currently sits above the manifold but plans
are afoot to change this) but otherwise the engine is stock.
Has anyone else experienced backfiring or got any suggestions (other than
changing gear at 7200rpm :-)?
Also, for those interested, I had my muffler replaced a few months ago in
order to do the spare-wheel-under-car conversion. This resulted in a nasty
LOUD buzz from 5000 rpm upwards. After visiting 4 different Pit Stops and
receiving 4 different answers, I was beginning to think the science of
exhausts was back there with druids and witchcraft. I visited Wolf Mufflers
in Mt Eden following someone elses recommendation on this list. The guy
there explained the problem and recommended changing the muffler to a
straight through muffler and replacing the cat with a resonator (in
fairness, Glen Innes Pit Stop did get the same answer as Wolf, but didn't
explain why and were an extra $50). Result is slightly louder exhaust at low
revs but much nicer sounding.
Nig.
JST4FN
Nigel Hughes
Post by Nigel Hughes » Sat Mar 16, 2002 2:48 pm
Thanks heaps to Fletcher for the LED/Resistor article
http://www.mx5club.org.nz/maintenance/e ... agnostics/
JAF wanted to charge an hour to get a diagnostic done! Jaycar charged $1.65
for parts.
I assume 10 is shown as one long flash rather than 10 short flashes? Seems
to have narrowed down the cause of the backfiring to airflow meter and
thermistor. Airflow meter seems to be pretty close to the resistance
specified in Rod's Miata manual (using the crappy multi-meter I had to hand)
so I'm assuming a wiring problem... anyone know a good auto-electrician in
central Auck or East Tamaki area?
Thanks,
Nig.
JST4FN
Return to “2002”
