octane
octane
Mine was driven to In'gill from Ak by my son on 96 but I always use 91. I must note though that he got a better fuel consumption figure than I do on open road. (Must try a tank of 96 myself sometime) Also as an added difference. The tyres were pumped up to 30 by the tyre warehouse in Ak that fitted them where I use 26. How many variables do you need?
octane
It depends on timing settings (and other modifications), 91 is fine for
standard timing but if its advanced to 14 degrees or more, you may find you
need to up the octane to 96 - listen for 'pinking' (pre-detonation?). I'm
sure that this has been discussed a lot by more knowledgable people than me
I don't know whether the search is working yet, zorruno? But thats
probably the best place to start.
Mine is advanced to 14 degrees but there is no pinking and runs fine on 91
Hope this helps
Graeme
D4NGER
Hope this helps
Graeme
D4NGER
octane
anyone else here found that Gull "91" runs better on a timing-mod'd engine ?
I did the timing bump, but I used the Force (instead of timing light
Graeme Naisbitt <graemen@dmd.co.nz> wrote: It depends on timing settings (and other modifications), 91 is fine for
Hope this helps
Graeme
D4NGER
Hope this helps
Graeme
D4NGER
octane
This may still be true of 91 and was certainly true of 96 Gull fuel
initially (usually rating 98 and 99 octane), but the latest consumer
magazine indicates that Ministry of Economic Development tests over the last
couple of years "have not found Gull fuel with an octane rating
significantly higher than 96."
Nig.
JST4FN
Nig.
JST4FN
octane
I thought I'd try Gull since I read this:
The small number of samples with significantly higher octane appear likely to have been sourced from overseas.
in here:
http://www.ess.govt.nz/rules/petroleum_fuel_2000.htm
seems true so far. Definitely less pinging when pulling out of intersections etc.
in here:
octane
This isn't in an MX5 but is all about Octane - Having a modded twinturbo
car Octane ratings are quite near and dear to my heart (and to save
expensive holes in pistons).
I've found the cleanest, highest octane fuel is BP "Ultimate" 98. Gull
96 tends to run quite dirty with the exhaust turning a bit blacker than
BP, and after a couple of tanks my car starts running a little rough low
down. Caltex 96 seems to be quite clean burning like BP and is my 2nd
choice after BP 98, but doesn't have the octane. I've heard reports that
BP 98 burns a lot hotter than normal fuels so probably suits my car best
as I run cold race plugs in it - might explain the clean idle as it
keeps the plugs at their self cleaning temp.
I usually get a pinking around 3000rpm before the engine comes on boost,
the current program advances the timing a tad too late for "normal" 96's
(I can actually feel the ignition change on the bridge). So a 80kph 4th
gear WOT experience on the bridge, Caltex pinks a little, Gull a little,
BP hardly anything.
Mobil Synergy 98 I tried twice from two different places (Quay St and
Parnell). The dirtiest fuel I have ever put in my car.. backfired on
changes and ran rough as after each tank.
Then theres Challenge Racegas
Rowan
BP hardly anything.
Rowan
octane
ok, without me rummaging through auckland library for the mx5 manual, can
you guys advise hints/procedure on altering the timing. i have all the tools
and timing gun and have done this many times on previous vehicles. Due to
this i know there are little tricks that only mx5 owners would know of.
What is the standard degrees advance on the 1.6?
THANKS!
THANKS!
octane
Hi,
Stock timing on a 1.6 is between 8-10 degrees. All the info you need to set
up the timing (including the tricks) is here :
http://www.miata.net/garage/ignition.html
Hope this helps
Graeme
D4NGER
Hope this helps
Graeme
D4NGER
octane
The four majors all take their fuel from Marsden point (which they all
own shares in)... its the same fuel.
They agree this is true, but claim to each add their own additive
package, to individualise it... They do all add a package, and they
each call it a different name, but I wouldn't be surprised if they
were all actually the same bunch of chemicals...
Some people report bad fuel from the same station again and again
(water in the tanks?) but I've never heard of bad gas from the same
brand in areas covering a wide selection of service stations...
The exception to this is Gull, who source their fuel from Asia.
Challenge! used to source theirs overseas, but it too comes from
Marsden point, now that they sold out to one of the majors (Shell?)
My point is, unless theres something wrong with your local Shell's
tanks, I doubt you'll notice a difference...
octane
It wouldn't be that. Water collects at the bottom of the tanks andSome people report bad fuel from the same station again and again
is not drawn into the pumping system. I remember 20 years ago doing
daily tank measurements with a long dipstick. We put "ullage paste" -
water-reactive paste - on the end of the dipstick to judge how deep
the water was.
Mark
