Whipping your top off
Louisa Currie
Post by Louisa Currie » Thu Jan 10, 2002 1:12 pm
Hmmmmm - thats a little harder. :)
I have tried but I end up contorted rather terribly between the steering
wheel and the gear shift!!! I've had a passenger put it back up while I
drove though... and while he won't admit it I think I heard something snap
in his lower back when he did it!! (big grin)
Phil McArthur
Post by Phil McArthur » Thu Jan 10, 2002 1:28 pm
I'll be sure and keep an eye out for you at the lights whipping your top
off, Louise...
(sorry, couldn't resist saying it)
Louisa Currie
Post by Louisa Currie » Thu Jan 10, 2002 1:42 pm
Indeed...
But... if you check my message - I worded it whipping THE top off not MY
top off to avoid such confusion.
A bit of sun around in Auckland today - might just have to do it on the
drive home...
Graeme Naisbitt
Post by Graeme Naisbitt » Thu Jan 10, 2002 1:58 pm
Bah, I had to put my top up yesterday - something to do with all that
rain... No way will it be up tonight though :)
Gram
D4NGER
Ian Watson
Post by Ian Watson » Thu Jan 10, 2002 2:26 pm
the Mk II's roof must be different - from the drivers seat I can easily
reach my left arm back to the handle in the middle of the roof and with one
smooth pull the roof's up - no problem - perhaps it's better balanced or
something.
derek.elliott
Post by derek.elliott » Thu Jan 10, 2002 2:35 pm
Great advice... That is exactly what I do... or should I say did until my
shoulder went ... pop! followed by several expletives.
Derek.
On 10 Jan 2002 at 14:06, nmr@iprolink.co.nz wrote:
Remove seatbelt.
Lift arms high above head.
Lean to left so that right arm clears left side of seat.
Lean way way back and stare at sky.
Back of hands should be touching the roof in the vicinity of the
handle. (Well
David
Post by David » Thu Jan 10, 2002 2:39 pm
It is possible to do a one arm roof raise in MK1 from the drivers seat with
seat belt on! You dont even need to take your eyes off the road. Although it
probably depends on drivers height and arm length.
DB
Louisa Currie
Post by Louisa Currie » Thu Jan 10, 2002 2:44 pm
I'll give this method a go tonight. However I fear that my stature of five
foot nothing will preclude my ability to complete the undertaking :)
Anyway - enjoyable top down driving those lucky enough to be in the sun!
redwon
Post by redwon » Thu Jan 10, 2002 2:57 pm
Sure it is.
Just order the ambulance before you attempt it.
Steve
jeff
Post by jeff » Thu Jan 10, 2002 5:23 pm
just leave the rear window unzipped all the time and
you can flop the top up and down to your hearts
content! (takes maybe 5 secs, including lowering the
windows an inch) If puny little me (65kg!) can do,
I'm sure you all can too...
--- nmr@iprolink.co.nz wrote:
The point is that you are NOT twisting your back.
NB this does NOT work at speed ;^)
terribly between
the steering wheel and the gear shift!!!
Have you worked out how to whip it back on again
from the driver's seat?
Send FREE video emails in Yahoo! Mail!
http://promo.yahoo.com/videomail/
Scott Elder
Post by Scott Elder » Thu Jan 10, 2002 5:52 pm
Im sorry that kind of thing just cannot be avoided :)
Mark Roberts
Post by Mark Roberts » Thu Jan 10, 2002 8:19 pm
Nah. Arm strength and willingness to entertain chiropractors' bills for the
next n years.
SG & NA Fisk
Post by SG & NA Fisk » Fri Jan 11, 2002 9:57 pm
Well I can't put the top up while in the car so I either pull over or if in
(rarer) town get out & do it at the lights - only takes 5 seconds. Had a
Lotus owner tell me he was envious as it takes him 5 minutes to put up his
bows & install the top - by which time he is often wet
Steve & Zed -
nmr
Post by nmr » Sat Apr 28, 2007 9:42 pm
Remove seatbelt.
Back of hands should be touching the roof in the vicinity of the handle. (Well
they do if you are my height.)
Hook fingers under metal bit.
Brace legs under whatever.
Clench back muscles.
Lift strongly and smoothly using the strength of your arms, not your back.
nmr
I love being able to sit at the lights between a break
in the rain and whip the top off (grin). Unzippings
too much of a hassle.
Have you worked out how to whip it back on again from the driver's seat?
Mark
Return to “2002”
