Hello all!
We installed the rear Koni's on the car today, and discovered a few things we
didn't expect. The 12mm drill bit needed to drill out the old bump stops
didn't fit our drills, but we managed to borrow a drill that could accommodate
it, and also we needed a 19mm socket, as that is what the Koni's use.
Also, make sure that your spring compressor isn't the sort that has to go up
the middle of the spring, as this won't work because the shock is in the way.
Have fun!
Koni Installation
