I have a 1998 mx5 imported from Japan that I purchased 3 months ago having
owned a 1990 model for the last 3 yrs
The problem is surcing parts for the hood catches ! It appears that you can
only buy the whole thing for around $350 nz !!! seems a lot when I only want
the plastic bush thingy that is screwed to the underside of the catch and
locates in the windscreen . Any ideas ?? thanks
Nic Siggs
From MattGunn@newstalkzb.co.nz Fri Apr 27 15:46:41 2007
Subject: RE: Soft top catches
Date: Wed, 10 Oct 2001 06:49:57 +1300
Thread-Topic: Soft top catches
Thread-Index: AcFQoUZiGT/qCqqdRFyJPo6EcIPQtgARlr8g
Message-ID: <JL4DMC.A.NM.BVXMGB@L733>
What about glue , or blue tac ???
Soft top catches
Soft top catches
What about trying Mazline Partsworld? They are in Christchurch but have second hand as well as new parts at reasonable prices. Phone 03-377-2201. They specialise in Mazda parts.
Tina
On Tue, 9 Oct 2001 21:55:36 Nic Siggs wrote:
Tina
Join 18 million Eudora users by signing up for a free Eudora Web-Mail account at http://www.eudoramail.comI have a 1998 mx5 imported from Japan that I purchased 3 months ago having owned a 1990 model for the last 3 yrs
The problem is surcing parts for the hood catches ! It appears that you can only buy the whole thing for around $350 nz !!! seems a lot when I only want the plastic bush thingy that is screwed to the underside of the catch and locates in the windscreen . Any ideas ?? thanks
Nic Siggs
Soft top catches
Nic
I to own a 1998 MX5 thou NZ New have had a look at mine but cannot find a
plastic bush thingy all mine are metal.
Is it under the Metal Catch?? on the front catches to the left and right of
the top windscreen??
Geoff Watkins
Geoff Watkins
Soft top catches
Hi nic
If it is just a bush any engineering machine shop should be able to make one
for you at a lot less than $350.
Regards Kevan
Regards Kevan
Soft top catches
Hi I perhaps didn't explain this prob very well so I'll try again,
The plastic part in question is secured to the catch on the hood, if you take
off the catch and look on the underside it is screwed on their, as I haven't
actually bought a new car I can't say whether the part covers the lug that
locates in the windscreen or not but I have made that assumption (If any one
knows please tell me) The parts fiche is pathetic but it does show the part as
separate from the catch although not priced separately .
Strangely enough it seems that an owner in the UK has the same problem and was
asking about it in August on one of the UK mx5 sites that I came across (I
have emailed to find out what they did ) This may not be a problem for the
vast majority of cars here, I tend to think that the part probably wears out
or breaks off quit quickly and the catches are readjusted to suit . My car's
hood is usable but it is not as I would like it to be and indeed not as good
as the old car was, undoubtedly new catches would fix the problem but just
possibly 2 parts that could not possibly cost more than $5 and about 10
minutes of work would also fix it (why don't Mazda nz stock them ?? or Mazda
UK for that matter )
Soft top catches
I know the piece you speak of. Black plastic the shape of the end of a finger
with a tab with a screw hole in it, right? Mine cracked on my first MX5 and I
glued it back together. You should be able to get one from a dismantler. I
wouln,t try securing your top with out it as your top may leak. You may be
able to improvise somehow.
Carl
Carl
