Tops
Phil Dyer
Tops
Post by Phil Dyer » Wed Sep 19, 2001 7:56 pm
Noticed that the new top - done before I bought it - catches the passengers
door when it is opened. The corner is a little tight. Is there a simple way
to fix this, other than not taking passengers?
Phil
Have you visited http://inet.net.nz/~pdyer yet?
Tops
Post by zorruno » Thu Sep 20, 2001 9:06 pm
Does it catch the door or the window? I have seen some windows catch the
top when the door opens, if the windows rise up too far. The windows can be
adjusted - but I doubt the door can! You might also be able to adjust the
top slightly from side to side at the top latches - but I don't know if if
they adjust sideways (never tried)
hope this helps
zorruno.
passengers door when it is opened. The corner is a little tight. Is there
a simple way to fix this, other than not taking passengers?
Phil
Phil Dyer
Tops
Post by Phil Dyer » Fri Sep 21, 2001 7:20 am
It is the window - how do you adjust the window height stop? (other than wind
it down a bit?)
Phil
rossandmeg
Tops
Post by rossandmeg » Fri Sep 21, 2001 8:52 am
Take the door panel off and wind the window down.You will see the stops from
the top.
They are very easy to adjust.
Ross Harvey
Return to “2001”
