MX5
Mark O'Donnell
MX5
Post by Mark O'Donnell » Sun Aug 19, 2001 10:45 pm
1. Where can I get a manual for a 1989 Eunos Roadster, recently imported
from Japan, with no manual at all.
2. The hardtop on the car is fitted with catches at the front (like the
soft top) that connect to the windscreen frame, but it also has the same
catches on the sides near where the seat belts swivel is connected, but
there is nothing on the car frame to connect to. I take it this hardtop
must be from a later model? Can I get the parts that the catches can
connect to? Will it be worthwhile to do this?
Thanks,
Mark O'Donnell.
peter
MX5
Post by peter » Mon Aug 20, 2001 12:02 pm
I'm curently using the Haynes manual... available from Repco Autoparts / Whitcoulls etc.
Your hardtop should clamp onto 2 chrome "bolts" that sit on a chrome piece between the boot and the roof strip... if
they're missing you can pick them up from Mazspare in Avondale.
Peter
DRGN-1
Return to “2001”
