Brighter Brake Lights (was Re: Indicator Conversion)
Post by zorruno » Thu Jun 28, 2001 4:00 pm
You'll be running another 5A (more with inrush current) with bulbs that
size. That is double what is drawn at present with three 21W bulbs. Stop
fuse is 15A, and you could uprate to 20, but I'd recommend using a relay
rather than just using a larger fuse. Much safer for your wiring! Your horn
is also on this circuit I believe, so if you brake and push the horn, and
the fuse blows...no horn, no brake lights...
Return to “2001”
