Valve gasket cover
VIKING RACING
Valve gasket cover
Post by VIKING RACING » Fri Jun 22, 2001 7:48 pm
Hi there
Have anyone changed valvecover gasket lately?Is it difficult, how much for the
gasket?
John
JOHN
Koni . Eibach , MazdaSpeed roll bar, Jackson Racing Chassi Braces, ENKEI blingwheels :), TURBO+go fast stripes
Fletcher Blades
Valve gasket cover
Post by Fletcher Blades » Fri Jun 22, 2001 9:54 pm
I dont recall the price of the gasket, but its a very easy job.
Just remember the 10mm bolts aren't that big and you dont need to do them up
very tight... just enough to squash the rubber gasket a little. Some people
break them...
Fletcher Blades
Valve gasket cover
break them...
Gary Morrison
Valve gasket cover
Post by Gary Morrison » Sat Jun 23, 2001 12:16 pm
And theres a little bit of silicone gasket sealant needed each side of the
camshaft bearing housings at the front, and either side of the cam angle
sensor at the rear. If you miss those you might be left with some oil leaks.
Gary
Gary Morrison
Valve gasket cover
Gary
Return to “2001”
