damn,
I took my mx5 for a run at lunch, and the clutch is slipping under
load (5000-6000 rpm) in 2nd and 3rd gear.
Can anyone recommend someone good/honest in Auckland to check the
clutch out and see if it is slipping or needs adjustment?
If it needs replacing what cost should I be looking at?
Rob
slipping clutch
slipping clutch
I had the same thing happen to me a couple of years ago, one Friday on
the way to work.
I got good service from Sterling Brake & Clutch in Onehunga. I phoned
them around 8:30 am and I picked up the car, fixed at 4:00 PM.
A new clutch kit was fitted and some leaking oil-seals replaced for
about $600 all up.
I think it was about half and half parts and labour.
This was the day before a club track-day at Pukekohe, so I was really
pleased to be able to get same day service.
the way to work.
about $600 all up.
slipping clutch
I just got my clutch done by Andrew at Bavarian Motors near Wairau Park,
Auckland. I know he did an amazing job because I watched him do it. He
showed me that my clutch was completely worn, the pressure plate was broken
and the clutch slave cylinder was leaking. Yip... a genuine clutch
hat-trick. AND he got my drive shaft reconditioned, the joints were worn and
sticking. AND he skimmed the flywheel.
I have pictures of the wear/damage and the new clutch if anyone is
interested.
Incidentally the symptoms for the above problems were that the clutch was
starting to slip, I couldn't change gear and my clutch fluid was
disappearing. I made a couple of very interesting (and stressful) drives
with only fourth gear available (one home and one to the garage).
interested.
slipping clutch
Was that the day you had to be towed from the mud at the end of the back
straight ?
straight ?
