attn Glen
Ray
attn Glen
Post by Ray » Mon May 14, 2001 6:49 pm
Hmmm!!!Yep! point taken, also if it was 316 stainless, or even a lump of bog (heaven
forbid), would cause the same problem, but i must add you dont know its a stone yet,
you could always attach a grease nipple and fill it with grease, but seriously Glen
if you want to use a hole cutter, start with a 12mm right underneath at the bottom
out of imediate sight some where near where the sound is then use a gas welding rod
and fish for it, you might be able to see it to know how big and what it is, you
could then use a rubber bung to plug the hole again! not the best way but could stop
you going mad eh!
good luck
Ray :-)
interesting point on the 626 relays eh? any idea what year 626?
Return to “2001”
