Soft tops ... unzip or not to unzip????
ANDREAS LUNDH
Post by ANDREAS LUNDH » Thu Feb 08, 2001 9:48 pm
Hello there all,
Can someone please tell me when folding the soft top
down, is it necessary/vital to unzip the plastic
window first.
What have you all found in your experiences with this?
Your advice(s) would be appreciated.
Sincerely
Andrew
- Feeling a little bored? Need some entertainment?
Colin
Post by Colin » Fri Feb 09, 2001 9:08 am
Hi, I have two thoughts.
Firstly you can fold the roof without unzipping the window. You must use a
foam roll on the outside of the window as you lower the roof.
Results of not doing this include creasing and folding.
Secondly and I believe the preferred method is to always unzip and to lay
the window flat with a protective cover both sides.
The cover both sides prevents the rub and scratch marks appearing as the
folded roof vibrates and moves while driving.
I have used two towels with good success. There are some good felt lined
ones available commercially.
It is I think a good idea to release the front roof clamps prior to zipping
or unzipping as this relieves strain on the zip.
I have used 'Mothers' plastic polish massaged into the clear window and then
buffed off. Works well.
I know of a car parked in a frost that split the window as it was lowered
due to the cold. I surmise that they may get a little brittle at low temps.
Hope that helps.
Colin
Charles Lynch
Post by Charles Lynch » Fri Feb 09, 2001 10:39 am
I know this is contrary to every piece of MX5 advice known to man (or woman)
but I don't bother unzipping the window. I've never had a decent roof and I
know I'll need to replace it some time, so I don't really care about the
back window.
However if the temperature is low enough though the window WILL break. This
happened to me in winter a couple of years ago, late at night when the
temperature was probably about 5C.
Luckily I won a new back window from Al's upholstery, so I didn't have to
buy a whole new roof.
If anyone in Auckland has a back window that is about 1.5 years old and that
has been concienciously unzipped and layed flat every time, we could perhaps
do a comparison against my back window which is now 2 years old but hasn't
been unzipped in the last year and a half. The results could be be
interesting.
Chic
Gary Morrison
Post by Gary Morrison » Fri Feb 09, 2001 11:37 am
back window.
Anarchist
Blts
Post by Blts » Fri Feb 09, 2001 10:51 pm
Like Chick, I don't unzip my roof (cause the zip is buggered), but I use the
"two towel method" of window protection. Unfortunately, with the amount of
time the roof is down the window not only has a large crease mark, but now
sports a 3" split vertically thru the crease. The car lives in a garage
when not in use, so the elements can be ruled out.
Bill
Return to “2001”
