Directional and non Directional Tyres
Geoff Watkins
Post by Geoff Watkins » Wed Jan 24, 2001 7:07 pm
Hi All
Can anyone please explain the Difference and is there WOF regulation saying
that you cannot mix them on a low performance car
Geoff
PS
there is one re Radial and Cross Plys
ian cole
Post by ian cole » Thu Jan 25, 2001 8:26 am
Geoff
In the current WOF regs a wof will be declined if there is a mix of
directional and non directional tyres on the vehcile at time of checking.
Space saver tyres are also not allowed on a vehicle at time of wof check.
Post by zorruno » Thu Jan 25, 2001 9:25 am
I'd be worried about mixing any tyres left to right as it would be very
likely to upset the handling/cornering characteristics, but front to back?
Would make a difference in handling, but would be no different to using
cheap tyres all round I would have thought - which is WOF'able.
You asked the difference - I'm assuming the difference between directional
vs non-directional? Directional tyres are made in such a way that they are
designed to give performance benefits only if they are rolling in one
direction. They must be mounted on the car the correct way round. They
usually give better performance (and are more expensive) than
non-directional tyres. Directional tyres will have an arrow on them marking
correct rotating direction.
Anyway - even to ensure I got a WOF, I'm not sure whether I'd like to call
my MX5 'low-performance' ... :)
H.
Geoff
Hi All
saying
Peter Sweetman
Post by Peter Sweetman » Thu Jan 25, 2001 10:07 am
Tyre construction can also play a part. Have you ever seen a HIGH
performance motorcycle tyre after a serious thrashing. ( Motorcycle tyres
are usually directional.) As the tread wears and is chewed up left and left
tattered towards the edges, the join where the tread is wrapped around the
case of the tyre often opens up showing the overlap. With the tyre on the
correct way this is not a problem. With the tyre spinning in the wrong
direction there is potential to lose the tread.
Gary Morrison
Post by Gary Morrison » Thu Jan 25, 2001 10:08 am
I think the direction nature relates to their water pumping ability...
reverse them and in the wet they may be a problem.
Gary
Geoff Watkins
Post by Geoff Watkins » Thu Jan 25, 2001 12:28 pm
Many thanks for the info
No it is not a query about a MX5
A Lady from work bought a Mazda Demio import from a Car Dealer Months ago.
The Warrant has just run out and she got rejected due to the above Mix.
I suggested she takes it back to the Dealer and ask how it got a Warrant in
the first place.
Would you Like a MX5 Calender(CHCH Designed) and our latest News Letter E
Mailed to you From the MX5 Club CHCH
Geoff
Return to “2001”
