KYB non-adjustables
Simon Hardman
KYB non-adjustables
Post by Simon Hardman » Sat Jul 30, 2005 1:54 pm
If someone out there has fitted KYB non-adjustables (GR-2) on an NA mx5 can
you confirm if you had to drill out the D-shaped hole in the rear top mount?
I am pretty sure I've been sold the wrong shocks and the part numbers don't
add up, but I'd like to be sure for when I take them back. Next time I'll
check _before_ I remove the existing shocks :-)
Thanks,
Simon
Wayne Sinclair
KYB non-adjustables
Post by Wayne Sinclair » Sat Jul 30, 2005 4:01 pm
Simon
I fitted adjustable KYB-AGX shocks to my 5 all round and they bolted
straight in (adjustable by external knob) no alterations at all.
Go to the following address and see if the part numbers are correct for your
model (make).
http://www.kyb.com/catalog/index.php?Ac ... &x=62&y=14
Good luck
Wayne
Simon Hardman
KYB non-adjustables
Post by Simon Hardman » Sat Jul 30, 2005 4:05 pm
Cheers Wayne. Definitely the wrong shocks then...
Simon
GEEMCB
KYB non-adjustables
Post by GEEMCB » Sat Jul 30, 2005 4:48 pm
Simon
My NA has KYB Hillclimb shocks on it - that's how it was when I bought it.
You're more than welcome to take a look at how the install has ended up, but
I've no idea how it was done. Not sure if that helps. I'll be at the tech
day tomorrow.
Regards,
Greg
Greg
1990 V Special
Simon Hardman
KYB non-adjustables
Post by Simon Hardman » Sat Jul 30, 2005 8:19 pm
Thanks, Greg, but I'm at the wrong end of the island. The problem is solved,
the store just got one digit wrong on the part number when they ordered the
shocks.
Return to “2005”
