Installing a radio
DBM58
Installing a radio
Post by DBM58 » Fri Jun 10, 2005 10:38 am
Recently I suggested that when fitting a radio, instead of cutting wires, an alternative would be to source the the appropriate plastic housing from a cabling / wiring supplier. I am now of the view that there is an easier way: (easier because the cost will not be high and unless you have a suitable crimping tool fitting the terminals on to the wires is a very fiddly process)
ie. Ed's Autos
75 Peary Road
Mount Eden
Auckland
Ed supplies the harnesses already made up that will plug directly in to the two sockets in the MX5. The othe ends of the wires are bared ready to connect to the similarly bared ends of the harness supplied by the radio manufacturer.
Using Gazza'a information:
Here goes. From a wiring diagram so no guarantees :-)
Ignition - Blu/Blk
Battery - Blu/Red
Earth - Make a new one is best.
Speakers Front
L+ Red/Wht
L- Red/Grn
R+ Blu
R- Blu/Yel
Speakers headrest
L+ Red/Blu OR Blu/Orange
L- Red/Yel
R+ Blu/Or OR Red/Blu
R- Blu/Wht
Power Areial LtGrn/Yel
Or zorruno's link: http://www.mx5club.org.nz/downloads/spe ... diag_2.gif
these should be simple to join.
David Moughtin
From m.mccready@gmail.com Fri Apr 27 17:01:23 2007
h=received:message-id:date:from:reply-to:to:subject:in-reply-to:mime-version:content-type:content-transfer-encoding:content-disposition:references;
b=p/5BYWNtZ2UaCgxmByLGDh+N8ntGkOuurNCgdP4BUgQOV88Zd61ri3mma72VrQgNqRfD/9bfvA4TMWqBb5Nzq3ANyUOi6ibBo2DlMm/YLgGv58sx6nwRNygvV5RqGyaI/7J+eGlQ3tuaCF56+IWbFImYmuM9EMArvpSsJwx/2iE=
Date: Fri, 10 Jun 2005 10:54:44 +1200
Subject: Re: Installing a radio
In-Reply-To: <994DA1DB154EBC4AB8D1D7B31A61B05E2760C8@nvakfps.snackmate.com>
Mime-Version: 1.0
References: <994DA1DB154EBC4AB8D1D7B31A61B05E2760C8@nvakfps.snackmate.com>
Message-ID: <EjabrC.A.o9.UdYMGB@L733>
There is also another option, Repco sells premade cables to got
between any aftermarket stereo and any car harness, you just get the
cable for each end and clip them together. And for ~$15 each its not a
bad price.
Mike
On 6/10/05, David Moughtin <Davidm@snackmate.com> wrote:
David
DBM58
Installing a radio
Post by DBM58 » Fri Jun 10, 2005 1:11 pm
Another suggestion - listen to Mike, his is by far the easiest solution.
David
David
ianbell
installing a radio
Post by ianbell » Fri Jun 10, 2005 8:59 pm
In addition to David's comments re buying finished radio harnesses ( or
cables). I am installing a Panasonic Radio/CD at present (Gazza's old one) and
have purchased complete wiring looms from a car accessories shop. The cables
were Audiologic brand, made in Penrose, Auckland. To connect the Panasonic to
the MX5, I needed cable WH531 (Mazda 1990-01) and cable WHPS3 (Panasonic 16
pin), and priced at $12 each. They had plugs at both ends, which, when joined,
made 1 complete cable for the MX5/Panasonic combination. I would assume that
the WH531 combined with another cable will allow other brands of radio to be
easily fitted to the MX5.
Ian Bell
CHN433
From m.mccready@gmail.com Fri Apr 27 17:01:20 2007
b=mbsADGSmRGJYpcS8a4Gz9/GkyJOhUK3vYmH7RZEOBR2ZHQNa7MmT6mQd9J92aWx/Qga5C1NFCW5APB1RBsGF1Bt/5qngLHxiw5prcVse1QPI1Zd6wCNrwXlGpciFU/Ay0lNKVfw5H8hPfNxFJNHTyFZErTVC5VSZXXdFhDz6SE0=
Date: Fri, 10 Jun 2005 21:43:50 +1200
Subject: Re: installing a radio
In-Reply-To: <001b01c56d9a$ace1fd90$1f3258db@BIASA>
Mime-Version: 1.0
References: <001b01c56d9a$ace1fd90$1f3258db@BIASA>
Message-ID: <k5XQiD.A.s9.UdYMGB@L733>
Yup,
I got the same thing recently for my new stereo, but got one to
fit a pioneer. It worked brilliantly.
Mike
On 6/10/05, Ian and Adele Bell <ballochbeatties@xtra.co.nz> wrote:
Return to “2005”
