In Call of Duty: Black Ops 7 (BO7), team coordination can make or break the flow of a match. Whether you’re playing Search and Destroy, Hardpoint, or Domination, stopping a well-coordinated team push can be the key to turning the tide in your favor. In this article, we'll break down 13 effective counter tactics to disrupt team pushes and give you the upper hand.
1. Use Smoke Grenades to Block Sightlines
When facing a team push, one of the first things you’ll want to do is disrupt their vision. Smoke grenades are perfect for blinding opponents, especially if they're stacking through a narrow choke point. If you're expecting a team to push from a specific route, toss a smoke grenade to obscure their view, forcing them to reposition or deal with the risk of unknown angles.
2. Exploit the Element of Surprise
As a team pushes forward, many players focus heavily on clearing the front. Use this moment to get behind them or flank their position. If you’ve been holding back and waiting for the right moment, now is your chance to wreak havoc from the rear. Just make sure to stay unpredictable—don't always push from the same direction.
3. Deploy Tactical Equipment
Flashes, stuns, and concussions are a few powerful tools that can throw off an advancing team. Use these devices to disorient the enemy, especially when you expect them to push through a known doorway or corner. Tactical grenades can slow their momentum, giving you an opportunity to pick off players or reposition for better sightlines.
4. Strategic Use of Dead Silence
The sound in COD BO7 can reveal a lot about your location. Dead Silence is a great perk to help you move undetected while the enemy is focused on pushing forward. Use this perk to flank or rotate to a position they won't expect. It’s all about using the map's sound design to your advantage.
5. Control High Ground
Having a high ground advantage is always powerful, especially when a team is making a push. Position yourself on elevated platforms to gain a better vantage point and force the enemy into difficult engagements. High ground will allow you to engage from a safer distance and make it harder for enemies to push up without significant risk.
6. Trap Your Opponents with Mines or C4
A well-placed mine or C4 charge can stop a team push in its tracks. If you know the team is about to rush through a particular corridor, consider setting a trap with explosive equipment. The key is patience—wait for them to get close enough, and detonate when the time is right.
7. Use the Environment to Block Routes
If you’re in a tight area and expecting an enemy push, consider using the environment around you to your advantage. Barricades, crates, and other obstacles can be used to block enemies or slow their advance. If you have access to vehicles or explosive barrels, don't hesitate to blow them up and create a temporary blockade.
8. Use a Loadout That Punishes Aggressive Playstyles
Certain weapons and equipment are designed to punish aggressive pushes. Shotguns and LMGs can be particularly effective at close quarters. Equip a weapon with high damage potential and spread to maximize your chances of shutting down a team push. Similarly, a loadout that focuses on long-range engagements can be useful if you're holding a distance and need to mow down enemies before they get too close.
9. Counter Their Specialist Abilities
Specialist abilities in COD BO7 can turn the tide of a battle. However, they are not invincible. If an enemy team is using abilities like the Tempest or Scythe, you need to be prepared. Use tactical equipment or throw off their aim with movement, making their abilities less effective. Also, keep in mind that disabling or eliminating the player before they can deploy their specialist is a game-changer.
10. Coordinate with Your Teammates
Disrupting a team push is much easier if you’re working with your own teammates. Be sure to communicate effectively, whether through voice chat or pings. A well-timed flank or coordinated use of tactical equipment can create confusion within the enemy ranks, leading them to retreat or scatter.
11. Use a Bot Lobby for Practice
To perfect your tactics, consider using a COD BO7 bot lobby. This allows you to hone your skills without the pressure of a real match. By getting familiar with enemy AI patterns, you can better anticipate how players will behave during a push. While you can buy COD BO7 bot lobbies for practice, don’t underestimate the value of learning in this controlled environment.
12. Disrupt Their Strategy with Counter-Intel
Keeping the enemy in the dark about your movements is crucial. Use UAVs, counter UAVs, and other reconnaissance gadgets to disrupt their plans. When the enemy doesn’t know where you are, their team pushes become less effective. Additionally, if you spot the enemy using UAVs or other tracking equipment, prioritize neutralizing these tools first.
13. Be Unpredictable
One of the most underrated tactics to disrupt a team push is simply being unpredictable. Don't fall into predictable patterns or positions. If the enemy begins to catch on to your playstyle, they’ll adapt. Mix up your movements, timing, and angles to keep them on edge. By staying unpredictable, you force the enemy to take unnecessary risks, making them more vulnerable to counterattacks.
Bonus Tip: Practice in Bot Lobbies for New Tactics
If you're still refining your playstyle or trying out new counter tactics, a COD BO7 bot lobby for sale can be a valuable resource. You’ll get the opportunity to test various strategies in a low-risk environment, helping you find the most effective counter to enemy pushes. It’s an excellent way to build muscle memory for those critical moments during an actual match.
Mastering these 13 counter tactics will give you the tools you need to disrupt team pushes in COD BO7 and come out on top. Whether you’re holding a specific position or looking to disrupt the enemy's plans entirely, it’s all about playing smart, staying unpredictable, and using the map to your advantage. With a little practice and tactical knowledge, you'll be able to outsmart even the most coordinated opponents.
U4N - How to Disrupt Team Pushes in COD BO7: 13 Counter Tactics
