MMOEXP- simple stance is ideal for launching moonshots
paleyShelie
Post by paleyShelie » Thu Apr 03, 2025 7:43 pm
In MLB The Show 25, mastering your batting stance in Road to the Show (RTTS) can be the difference between a struggling rookie and a perennial All-Star. A well-optimized stance improves timing, swing mechanics, and MLB The Show 25 Stubs overall hitting performance. Whether you prefer a power hitter’s aggressive setup or a contact hitter’s balanced approach, selecting the right stance is crucial.
This guide explores the best batting stances in MLB The Show 25, including current and former MLB stars, along with custom stance settings to maximize your player’s potential.
Why Your Batting Stance Matters
Your batting stance affects:
Timing – Proper positioning helps you read pitches better.
Power & Contact – Certain stances generate more lift or line-drive efficiency.
Comfort & Consistency – A natural-feeling stance leads to better plate discipline.
Whether you're a power hitter aiming for home runs or a contact hitter spraying singles, the right stance can elevate your game.
Top Batting Stances in MLB The Show 25
1. Yordan Alvarez (Houston Astros – Current Player)
Best for: Power hitters
Yordan Alvarez’s stance is perfect for generating home runs due to his balanced yet explosive setup.
Key Stance Settings:
Stat Value
Hand Waggle Rotation 50
Back Elbow Offset 50
Front Elbow Offset 50
Hips Offset (X, Y, Z) 50, 50, 50
Front Foot Offset (Z, X) 0, 0
Why It Works:
Keeps the bat in an optimal launch position.
Minimal movement allows for quick adjustments.
Great for players who want a compact yet powerful swing.
2. Shawn Green (Former MLB Star – Custom Stance)
Best for: Balanced hitters (Power + Contact)
Shawn Green’s custom stance is a fan-favorite for its versatility.
Stat Value
Hand Offset (X, Y, Z) 48, 70, 61
Hand Rotation 60
Hand Waggle Rotation 80
Hips Offset (X, Y, Z) 77, 65, 48
Front Foot Offset (Z, X) 48, 33
Why It Works:
Provides great plate coverage for inside and outside pitches.
Smooth load mechanism helps with timing.
Known as "The One" stance in the MLB The Show community.
3. Mark McGwire (Former Power Hitter – Classic Stance)
Best for: Pure power hitters
McGwire’s wide, simple stance is ideal for launching moonshots.
Key Features:
Feet wide apart for stability.
Minimal bat movement for consistent timing.
Works well for both left-handed and right-handed hitters.
Why It Works:
Helps generate maximum torque for home runs.
Great for players who struggle with timing (less movement = easier to sync swings).
4. Chipper Jones 2008 (Switch-Hitter’s Dream)
Best for: Switch-hitters & balanced hitters
Chipper’s upright, relaxed stance is perfect for tall players seeking a natural swing.
Key Features:
Bat close to the shoulder for quick reactions.
Narrow foot placement for better weight transfer.
Works equally well from both sides of the plate.
Why It Works:
Helps maintain plate discipline.
Smooth swing path leads to high contact rates.
5. Yoan Moncada (Chicago White Sox – Current Player)
Best for: Contact hitters with power potential
Moncada’s stance is similar to Chipper Jones, but with hands closer to the face for better pitch tracking.
Key Adjustments:
Some players widen the stance slightly for extra stability.
Works well for both power and contact hitters.
Why It Works:
Compact swing helps with inside fastballs.
Upright posture allows for better pitch recognition.
6. Ken Griffey Jr. (The Smooth Swing King)
Best for: All-around hitters
Griffey’s stance is iconic—fluid, balanced, and effective for both power and contact.
Key Features:
Slight bat waggle for rhythm.
Effortless weight transfer into the swing.
One-handed finish for maximum extension.
Why It Works:
Perfect for players who want a classic, effective swing.
Works well for lefties and righties.
7. Freddie Freeman (Los Angeles Dodgers – Pull Hitter’s Stance)
Best for: Left-handed pull hitters
Freeman’s stance is optimized for driving the ball to right field.
Key Features:
Bat rests behind the head for a quick load.
Back elbow up for leverage.
Slight knee bend for balance.
Why It Works:
Generates natural lift for extra-base hits.
Can be adapted for right-handed hitters with slight adjustments.
Best Custom Batting Stance Settings
If you prefer a fully customized stance, tweak these key settings:
Hand & Arm Positioning
Hand Offset (X, Y, Z): Adjusts how close your hands are to your body.
Hand Rotation: Affects bat angle (higher = more upright).
Elbow Offset: Determines how tucked or extended your arms are.
Lower Body Setup
Hips Offset: Influences weight distribution.
Front Foot Offset: Adjusts stride length.
Recommended Custom Stance (Balanced Approach):
Setting Value
Hand Offset (X, Y, Z) 50, 60, 55
Hand Rotation 65
Back Elbow Offset 45
Front Elbow Offset 55
Hips Offset (X, Y, Z) 60, 50, 50
Front Foot Offset (Z, X) 30, 20
Final Tips for Choosing the Best Stance
Experiment in Practice Mode – Test different stances against live pitching.
Match Your Playstyle – Power hitters should prioritize leverage, while contact hitters need quick bat control.
Adjust Based on Feedback – If you’re late on fastballs, try a more compact stance.
Conclusion
The best batting stance in MLB The Show 25 depends on your player’s build and hitting style. Yordan Alvarez and Shawn Green are great for power, while Chipper Jones and Ken Griffey Jr. offer balanced swings. If you prefer customization, tweak the hand, elbow, and hip offsets until you find the perfect setup.
By selecting the right stance, you’ll dominate at the plate and accelerate your Road to the Show journey toward MVP glory.
Which stance are you using? Let us know in the comments!
Want more MLB The Show 25 tips? Check out our guides on cheap MLB The Show pitching mechanics, Diamond Dynasty strategies, and RTTS training optimizations!
