Jackson / Sebring supercharger spare parts
DBM58
Post by DBM58 » Mon Nov 06, 2006 10:37 am
Driving around yesterday, I suddenley lost boost and power steering. The cause was one of the tensioner (I think that is the correct description) pulley wheels separated from its central bearing. Does anybody know if a replacement can be sourced in New Zealand, or can it only be bought from the original supplier in America.
David
David
Post by Growler » Mon Nov 06, 2006 1:21 pm
You could just change the bearing and push one back in. (Interference fit so will need a press of sorts).
Most engineering companies/supplies will be able to help you out. Seaco Bearings is one company that comes to mind.
Growler.
