Valve/Cam Cover Bolts - Torque settings
mikey
Post by mikey » Thu Aug 10, 2006 7:28 pm
Hi all,
I need some advice on torquing up the cam cover bolts.
The manual states 43 to 78 in-lbs, however I keep snapping the screws off when I go to torque it up. There is of course a little oil around however i'm getting no where near even 10 in-lbs before one of them snaps!
It took Mazda 2 weeks to get in another set of 11 after the first one snapped a couple of weeks back so I have plenty now to experiment with. Unfortunately i've gone through 3 tonight trying to get it sorted.... and i've had enough.
Help!
mx5mike
Post by mx5mike » Thu Aug 10, 2006 8:34 pm
You sure you are not getting inch pounds and foot pounds mixed up on your torque wrench?
[Posted via External Email]
GEEMCB
Post by GEEMCB » Thu Aug 10, 2006 8:48 pm
hi, Mikey
I've often found that some of the torque specs seem to be quite high - sway bar saddle bolts etc
When I replaced my cam cover gasket I used "guestimated feel" rather than spec torque. Not very scientific I know .....
I did tighten things up according to the sequence in the Haynes manual which took many iterations to complete. Part of the issue was the gasket maker I used in the gasket groove squeezing out a little as it bedded in.
Hope this helps ...
Greg
1990 V Special
mikey
Post by mikey » Thu Aug 10, 2006 8:49 pm
oh no... you are correct, I have been mixing up in-lbs with ft-lbs...
someone come round and tow my mx5 away.. I am not worthy!
Thanks mx5mike, you are a godsend!
Post by Growler » Fri Aug 11, 2006 10:26 am
mikey wrote:Thanks mx5mike, you are a godsend!
Purleese!!!! Mike...a godsend!!!
:D
Growler.
