Supercharger and fuel economy
DBM58
Post by DBM58 » Fri May 26, 2006 12:08 pm
I would be interested to hear what sort of fuel economy others are achieving in (NZ) cars fitted with a supercharger. Both around town and on the open road. I manage about 320km per tank around town.
David
Post by jif » Fri May 26, 2006 8:15 pm
hmm, well turbo here ... a shade over 10 km/l thrashing around town = 480km from a tank.
Divide kms by litres next time you fill up... the tank has nearly 10 litres left when on the lowest mark so it's conservative, not accurate!
zippy2
Post by zippy2 » Mon Jul 10, 2006 9:50 am
JR supercharger at 6lb, taking it easy, and not using boost too much about 10L / per 100km of mixed town and motoway, 30+L / per 100km on the track.
ham
Post by ham » Fri May 08, 2009 10:19 pm
Basic JR supercharger, mostly longdistance running, 9.9ltr/100
ham
Post by ham » Fri May 08, 2009 10:20 pm
that should have been 9.2ltr/100
Post by SLYDIT » Tue May 12, 2009 9:42 pm
did you get your bad running/idle issues sorted David? what was the cause?
Post by zorruno » Fri May 15, 2009 2:07 pm
SLYDIT wrote:did you get your bad running/idle issues sorted David? what was the cause?
Last time I spoke to David was a couple or three months back & he was looking at getting an ECU, not sure if he did. That was about the same time I got my Greddy Blue.
Post by sprsta » Fri May 15, 2009 7:24 pm
turbo here again
but im sure im using less gas than i did without the turbo
i dont know whether i am able to shift earlier now or the fact that i have a better tune off boost (idle) still have to idle at 1100 revs but its better than 1400 the cams are giving me headaches i guess ill sort it one day
Gravelben
Post by Gravelben » Thu May 21, 2009 9:09 pm
zippy2 wrote:JR supercharger at 6lb, taking it easy, and not using boost too much about 10L / per 100km of mixed town and motoway, 30+L / per 100km on the track.
30 L/100km is sure sucking through it, I thought I'd done well getting my standard Mk1 to 16.1 L/100km on track!
