na timing
na timing
So,went to 14 degree my NA today and when i jumped the diagnostics to set the idle revs i had to turn the screw out 2 turns and then found that it already had been done but when i unhooked everything the idle revs stayed as per normal so is it possible that when it was done they didn't set the idle revs rather just advanced the timing-btw when i set the idle revs properly it seems to have fixed the idle droop problem i had.
Users browsing this forum: No registered users and 106 guests
