air con delete
air con delete
Post by warrior » Thu Jul 16, 2015 8:27 pm
I want to get rid of the air con in my car to make it easier to put a intercooler in my sc car.
Is there anyone out there that has done this and is willing to give me a hand?
I am happy to throw a few beers your way.
Car is in auckland.
021796465
Post by Snapfrozen » Thu Jul 16, 2015 10:55 pm
Yep. Very very easy. Will post up more tomorrow
Post by Snapfrozen » Fri Jul 17, 2015 6:52 am
Where in Auckland are you? It's as simple as removing the compressor and following the lines and unbolting shit.
If it still blows cold air you have 2 choices. Assuming it's an original system the gas will be harmful foe the environment so when you open it all up it will release it. Or you could pay a company 300 bucks to drain it.
I didn't pay the 300 as my ac blew warm.
There's also a bolt you need to put in to replace the one from the ac bracket. Can provide you one as Kingdom order was 5.
Post by GRUVBB » Fri Jul 17, 2015 10:14 am
Warrior.... I have equipment to Reclaim gas compliently. No charge to you my friend. Only take about Quarter hour to setpup etc and then pack up
Post by warrior » Fri Jul 17, 2015 3:33 pm
Im in manurewa but happy to travel, the air con does not blow cold so im guessing the nasty stuff has gone? Or most of it anyway.
Post by warrior » Fri Jul 17, 2015 3:34 pm
But gruvbb if you can do it safely then we might as well do that first
Post by SLYDIT » Sat Jul 18, 2015 10:19 am
when you remove the compressor bracket there is a bolt that goes in through the oil pump housing.(front to back) this bolt MUST be replaced with a shorter one. its a finer thread than normal. it clamps the oil pump to the block. obviously your gonna have a leak or bad oil pressure if you dont replace it.
Post by Snapfrozen » Sun Jul 19, 2015 8:10 pm
Snapfrozen wrote: There's also a bolt you need to put in to replace the one from the ac bracket. Can provide you one as Kingdom order was 5.
Post by Euen » Mon Aug 17, 2015 8:20 pm
Warrior, if you want to get rid of a couple of kilos you can also get rid of the unit under the dash and replace it with the plastic duct from the non AC version. I just happen to have one available if you want to go that way. Send me a PM if you want it.
