What size tyre are you running on 8" rims?
Post by MrGrey » Fri Apr 03, 2015 4:00 am
hello again :)
I am looking at some 8" rims and was wondering what sort of tyre people are using on them and what they look like fitted (the tyre on the rims I mean) if anyone has photos. I gather that for a LVVT certification they need to be 225 wide unless they are a specific brand (I think firestone make a 205 that will pass certification but it could be another brand)
anyhow, if anyone has any pics of sexiness, I would be very appreciative.
Post by sprsta » Fri Apr 03, 2015 10:05 am
Falken do a 195/45/15 that can go on an 8.
https://docs.google.com/document/d/1cRj ... XRE68/edit
SKREEE
Post by SKREEE » Fri Apr 03, 2015 11:07 am
sprsta wrote:Falken do a 195/45/15 that can go on an 8.
I run 205/50/15s not huge stretch and are only a couple of mill off the standard rolling diameter from stock.
I do plan on 225/45/15 once these are past it however.
Post by evel » Mon Apr 06, 2015 9:19 pm
225/45 on a 8.
If you are gonna go 225/45 your only option is semi slicks, or import your own tires.
Post by MrGrey » Tue Apr 07, 2015 3:49 am
Thank you for the information and pics guys, I really appreciate it.
Skreee & Eval, could you please tell me what offset your rims happen to be?
SKREEE
Post by SKREEE » Tue Apr 07, 2015 6:10 am
mine are 20+ Pretty sure Eval's are 0
Post by CordedBowl » Tue Apr 07, 2015 7:37 am
Evel, are you running spacers too? Can't remember
Edit: I'm looking at getting some 15x8 +10's and running some 205 50's, hoping to run them without redonk camber
mjrstar
Post by mjrstar » Tue Apr 07, 2015 10:34 am
205/50 on 8's
SKREEE
Post by SKREEE » Tue Apr 07, 2015 4:32 pm
CordedBowl wrote:Evel, are you running spacers too? Can't remember
even with how low you are you should be sweet, at 20ish old stock height only rubbed on mega bumps and at full lock and that was just the plastic guard liners.
M&T rolled the lip on the back a little and I had to bend back the tabs in the front from the inner guard liners.
Post by evel » Tue Apr 07, 2015 5:44 pm
SKREEE wrote:mine are 20+ Pretty sure Evel's are 0
Yea the wheels are 15x8 0et. Im running a 15mm spacer to clear the brake caliper.
Here it is with no spacers, no flares on factory bilsteins. I thought I had more photos but i was probably too ashamed at the time
:oops:
Post by Angreal » Fri Apr 10, 2015 2:17 pm
Interesting to see the -15x8 on a stock car. The wheels I have are 15x8.5-15 and should be pretty much the same. Interesting to see how much it'll change the car...
mjrstar
Post by mjrstar » Sat Apr 11, 2015 10:15 pm
15x8 at 0p on the mx..
Post by warrior » Sun Apr 12, 2015 11:10 am
What size tyres?
Post by CordedBowl » Sun Apr 12, 2015 4:38 pm
15x8 +25, 185 60's looool.
mjrstar
Post by mjrstar » Mon Apr 13, 2015 7:47 am
warrior wrote:What size tyres?
205 50 15 off my 6 cylinder starlet.
Post by warrior » Mon Apr 13, 2015 9:45 am
Can you please post a picture looking down the side of the car? I want to run the same setup but want to know how far the wheels stick out
Post by evel » Sun Apr 26, 2015 7:14 pm
...my 6 cylinder starlet.
6 cylinder Starlet? :?
mjrstar
Post by mjrstar » Sun Apr 26, 2015 8:19 pm
warrior wrote:Can you please post a picture looking down the side of the car? I want to run the same setup but want to know how far the wheels stick out
No can do sorry, car now has a wider rear subframe and cut rear guards.
Blackrat
Rims
Post by Blackrat » Tue Apr 28, 2015 7:32 pm
We have 8" rims on the rear of our 2005 NC with 225x45x17 Bridgestone Adrenaline RE002 & 7 1/2" rims on the front with 215x45x17.
Car came into the country with these rims (Advan Racing) on it, have just replaced the old tyres (Dunlop DZ1?)
Very impressed with the Bridgestone, much quieter and seem to stick very well.
Post by MrGrey » Thu May 28, 2015 7:17 pm
Well, I have splashed out and bought some XXR002's off tardme (inc shipping they came to $905) and they are the same as the ones in Mrjstars pic but mine have black centers instead of gunmetal grey. I could have imported them for cheaper but for the sake of piece of mind in case something goes wrong I chose to pay a little more (its easier to hunt someone down here in NZ instead of getting screwed by someone in another country and have them laugh at your impotence (I had a bad experience many years ago when I was sent damaged products from Singapore and the seller knew I could do nothing about it and that has always left a bitter and mildly suspicious memory of online foreign purchases).
I plan on running 205/50/15's or 205/60/15's on them but may seriously consider running 225/45/15's although I know they will cost a small fortune.
Could someone in the know please clarify something for me...
I plan on turbo'ing my whip after winter (2low2c gave me the wise advice to wait until the roads are dry as my baby will behave differently with a new lease of life and I would hate to be a numbnut and stack my pride and joy) So after that is done I will have to be getting a LVVT cert because I like to be all legal beagle and from what their pdf guide says, for an 8" rim I would need to run 225 width tyres. However, I have been told that Falken make a 205 that will pass cert as they are the only manufacturer to guarantee the safety of their tyres on that width rim. So here are my questions:
1) if I went for a 225 width tyre, would any brand pass cert on an 8" rim?
2) if 205 Falken's would pass cert on an 8" rim, would it have to be a specific model of tyre or would any 205/50/15 Falken be ok?
3) if Falken's are fine for cert, where would be the best value place to get some? I find most tyre places a bit of a ripoff considering they would have to be ordering them in for me anyhow.
4) in regards to a LVVT cert, can I still mod my car after the cert is done without having to get it re-certed as long as the mods do not require certification? eg if later on down the line I got a fastback hardtop, would I have to get it re certed even though I normally would not need a cert for the hardtop?
Thanks again everyone for imparting your answers, feedback and suggestions
This is the LVVT tyre guide I am referencing:
http://www.lvvta.org.nz/documents/infos ... _Guide.pdf
This is a pic of the Rims I am awaiting the arrival of:
And although some will hate me for doing this (taste is subjective) I will be fitting flares onto my arches to alter the silhouette/profile of my car to suit the rims and make my car look a little wider. These are the flares I have been sitting on for about a year awaiting this upcoming alteration.
Post by Keith Jones » Fri May 29, 2015 10:23 am
Can't help on the tyre matters but you can mod the car after a cert providing the mods don't need certing, eg. you could upgrade the brakes, but couldn't fit adjustable coilovers.
jtsoldier
Post by jtsoldier » Fri May 29, 2015 1:19 pm
Is that actually the case?
I know someone who increased his ride height for Christchurch "roads" and was required to resubmit for certifying. As far as I'm aware, providing there is a certain clearance (can't remember off the top of my head what that is!) between structural components and road, a vehicle doesn't require to be certified for being lowered (or raised) to a point below OEM.
So raising it above that limit mean it doesn't need to be recertified, right?
It wasn't that coilovers had been installed - they'd already been certed for install.
I'm not being a trollfag, genuinely seeking clarification...
Post by marcellarius » Fri May 29, 2015 1:43 pm
If your car doesn't match the cert plate it's reason to fail a WOF. The plate specifies the ride height for adjustable suspension +/- 5%, wheel size etc.
Post by marcellarius » Fri May 29, 2015 1:49 pm
Also, this means you can't legally "unmodify" your car once certed. If you had it certed with adjustable suspension, you couldn't revert to OEM or another fixed kit without recerting to get the plate changed.
Post by MrGrey » Fri May 29, 2015 4:10 pm
Regarding the ride height, anything above 100mm is OK while adjustable suspension and going below 100mm require certification (this 100mm is from the ground to the bottom of the actual chassis)
-=edit=-
and when you cert your adjustable coilovers, they get certed for the height they are at the time of certification -/+ 5% so basically for your adjustable suspension to be legal, they want you to select a height and stay at that height (which kind of made the whole 'adjustable' aspect of adjustable suspension kind of redundant)
At least that is my understanding of the laws on ride height.
