NB brake pads?
NB brake pads?
I recently installed a set of used front calipers from a nb mx5 on my 1990 mx5, the rotors that came with the discs are 255mm, what is the correct chassis code for when i order new pads? Do all versions of the nb generation use the same size pads? Thanks for the help
Depends on which year they came from. Up to 01 uses db1282 and 01 on uses db1386
Check the lisying on my website
http://www.broomfish.co.nz/shop/product ... MX5%20NB8C
