- I only think 5.
by warrior » Mon Nov 17, 2014 5:28 pm
One of my cars has a strange viabration when taking off in first gear in the rear. I replaced the engine mounts as I thought it may have been that but it wasn't.
The car feels to shudder when taking off but only in first. It also brakes traction very easily in the rear when starting off in first and worse when turning (more chirping the breaking traction if that makes any sence) .
Any ideas?
by 4A-GE » Mon Nov 17, 2014 5:49 pm
Change the thread title before I start making bum jokes.
- I only think 5.
by warrior » Mon Nov 17, 2014 7:07 pm
Go for it
by Angreal » Mon Nov 17, 2014 7:27 pm
Diff mounts? I think my car used to be similar when I had two different rear half shafts on the car which pushed the diff out of alignment. Could the clutch cause it?
by siren676 » Mon Nov 17, 2014 7:53 pm
Axle tramp, mines doing it even after replacing every bush in the car, i have no idea what it could be. On mine the gearstick jumps around because of it too
- I only think 5.
by warrior » Mon Nov 17, 2014 7:57 pm
Yeah i am thinking diff mounts at this stage
by siren676 » Mon Nov 17, 2014 8:12 pm
Ive done them on mine and it still does it
Im suspecting the rear shocks are on their way out
- I only think 5.
by warrior » Mon Nov 17, 2014 8:25 pm
Have new shocks in mine
by 4A-GE » Mon Nov 17, 2014 11:37 pm
Frrrrrrppppp-p-p-p.
by Timmo » Wed Nov 19, 2014 8:35 pm
When you say it only happens in first, does that mean you've tried taking off in second and it doesn't happen? (if so that discounts things like a bent propshaft)
- I only think 5.
by warrior » Wed Nov 19, 2014 8:46 pm
Good idea.
by sprsta » Wed Nov 19, 2014 10:47 pm
possibly one of the inner CV on its way out?
universal on the drive shaft?
Worn bushes?
alignment?
If youre real low, check you haven't worn/broken the heads off the PPF bolts at the diff
by Euen » Tue Nov 25, 2014 2:03 pm
If all else fails, try one of these. Energy or Superpro diff mount bushes also help.
