by Snapfrozen » Mon Oct 27, 2014 4:08 pm
Haven't been on here in a dam long time - Have just run out of time with life etc. Am cleaning up my rebuilt engine at the moment and have a dilemma. Both my thermostat housings have the fucked hard line.
I remember Ross has these:
http://mx5mart.co.nz/db.cgi?db=mart&uid ... records2=1
But I'd like to avoid him like the plague and I don't want to buy a whole new housing. Options?
by SLYDIT » Mon Oct 27, 2014 5:13 pm
buy a 1/8" bspt tap. drill the old one out and tap for a new hose fitting in there.....easy. i use loctite 3805 to seal up stuff like that. best stuff ever.
by Snapfrozen » Mon Oct 27, 2014 5:51 pm
And just get a generic T like what Ross sells?
by siren676 » Mon Oct 27, 2014 6:08 pm
You'll either have to tap the housing and put in a 1/8th bsp fitting (make sure its 1/8" not 1/4" as youll crack the housing) or replace the whole thermostat housing ~$150 new from mazda
by 4A-GE » Mon Oct 27, 2014 7:29 pm
I have a spare upper housing.
by Snapfrozen » Mon Oct 27, 2014 10:29 pm
Is it in good nick? How much you after for it mate?
*EDIT* Nevermind, the lower is what I need.
by WideOpenThrottle » Tue Oct 28, 2014 8:54 am
I successfully soldered the hole in the lower one on our NB. Need to remove it though
by 4A-GE » Tue Oct 28, 2014 4:32 pm
Given that I have a whole motor I probably have the lower too. Remember I'm up the road so fire me a txt if you want to have a perv at it.
by SLYDIT » Wed Oct 29, 2014 9:06 pm
I wouldn't trust a used one. they fail all the time. you can buy the part from Mazda or drill and tap a fitting in. I have no idea how easy it is to get the old tee out and fit another Mazda one. but the drill tap method will work and hold.
Toolbox
by Toolbox » Thu Oct 30, 2014 7:20 am
I wouldn't trust a second hand one either, you have to ask the question is it worth a motor? A motor needs water and oil or it's Buggered it's as simple as that.....
by Skilfil » Thu Oct 30, 2014 11:04 am
Do it with a new one, or if you can wait a little bit IIRC they do an improved one in the states thats aftermarket, it won't corrode on you.
I've done this with the engine in the car, its a prick of a job, do it properly while its easy or you'll be swearing away for a few hours while you do it again.
mazline
by mazline » Thu Oct 30, 2014 11:37 am
You need these
- NA water thermo pipes.jpg (45.66 KiB) Viewed 17031 times
by SLYDIT » Thu Oct 30, 2014 6:04 pm
How are they actually held in? do you drill the old one out? are the new ones larger diameter?
mazline
by mazline » Fri Oct 31, 2014 10:14 am
They pull out ,we just screw a bolt up the guts and work it out,The replacement pipe's are exact dimensions ,We had these custom made oversea's for us.
Just quietly tap them back into place with a bit of liquid sealer.
We sell them as a pair.
PM me if keen for pricing,thought i had a add running for them.
