afternoon all is there a step by step instruction on how to install a soft top.
ive recently installed a haarts soft top and leaving it to stretch at the moment the problem i have atm is it wont fold down at the first joint closest to the front of the car something is stopping it for some reason it seems if i had to stretch it back it would just rip it? any info on why this is would help thanks.
soft tops
I think I had similar situation before...
Check your stainless retainer for rubber weather seal, It may be not quite in right position or you may have swapped front/middle or left right?
or make sure the tension wire is threaded the side correctly so not jammed.
Ben
