- I only think 5.
by warrior » Wed Sep 03, 2014 6:01 pm
I am trying to stick my mazda emblem back onto my nose cone, I have tried normal double sided tape but it is just not good enough.
When I got the emblem it had a grey rubbery substance to stick it on with and that worked great....any ideas what I can use and where I can get it from?
by siren676 » Wed Sep 03, 2014 6:06 pm
3M double sided trim tape, it'll never come off again though
- I only think 5.
by warrior » Wed Sep 03, 2014 6:07 pm
Where can I get it?
by siren676 » Wed Sep 03, 2014 7:43 pm
Usual auto stores should stock it
by SkilletKid » Thu Sep 04, 2014 1:23 am
If you want it to come off, 3M's clear mounting tape is pretty strong too. (quite thick with red backing paper)
by Stevo » Thu Sep 04, 2014 6:13 am
That 3M tape is the stuff to use but its expesive as you have to buy a roll.
Just rock up to your local panelbeater and ask for 100mm of it or whatever you need.
Probably charge you $1 if anything at all.
by WideOpenThrottle » Thu Sep 04, 2014 4:02 pm
Silicone adhesive from building supplies or silicone gasket maker from auto parts is what I commonly use for jobs like this..[mainly cos I always have them lying around]!
McNuggetBandit
by McNuggetBandit » Fri Sep 05, 2014 12:12 am
3 things that fix every car problem,
Cable Ties
Duct Tape
Gasket Goo
In this case gasket goo would work
紫色霧
1992 MX5 S SPEC Purple/Black
by sprsta » Fri Sep 05, 2014 7:34 pm
Come see me I'll reback it for you.
0211220097
it wont come off
- I only think 5.
by warrior » Sat Sep 06, 2014 2:14 pm
Thanks for the offer but I got it sorted.
