jordanmounfort
by jordanmounfort » Wed Aug 13, 2014 6:25 pm
hi every body i have recently bought an mx5 and i have fully serviced it including all filters plugs leads, however i am wanting to know why it is running like crap
the symtoms are in the cold morning it will take a few cranks till it starts not first pop. it has to think about its idle for a few seconds
but mainly has a flat spot just off idle and if you stall it sometimes it wont start for as long as 5 minutes and can be imbaressing if you give it full throttle it some times starts. i relize i may have more than 1 problem
any ideas or starting points on these
by BRM » Wed Aug 13, 2014 6:51 pm
Everything plugged in?
by Angreal » Wed Aug 13, 2014 11:11 pm
After market ecu?
by GRUVBB » Thu Aug 14, 2014 7:43 am
I had issues with stale fuel. Simple job to replace fuel filter and disconnect fuel line and then pump fuel out and replace.
PLSEME
by PLSEME » Thu Aug 14, 2014 8:35 am
Also worth checking tha CAS unit on the back of the head
bgg846
by bgg846 » Thu Aug 14, 2014 8:20 pm
Check your bypass hoses arent blocked. They control your idle air controll valve which im pretty sure has an automatic choke. It started. I had a similar problem and later in life it started overheating. after siezing my engine i found they were packed with old rusty water.
bgnz
by bgnz » Fri Aug 15, 2014 4:44 am
by GRUVBB » Fri Aug 15, 2014 10:35 am
Excellant post/link BGNZ!!
SKREEE
by SKREEE » Fri Aug 15, 2014 5:52 pm
Have you noticed a increase in fuel use? if so check your o2 sensor/s depending on age of mx5.
I got some oil on mine a few months back and had similar problems just with mega fuel consumption and stuttering in the early rpm range.
I just cleaned mine with a singlet and all was fine after but they are cheapish and easy to swap out anyway.
by 4A-GE » Sat Aug 16, 2014 8:49 am
I've been having similar issues. Suspect shitty battery or oxygen sensor. Plugs are 3000kms old. Guna pull them out today to see if they're covered in fucking rust again.
by SLYDIT » Sat Aug 16, 2014 9:14 am
mate if i wasnt at home with the flu i would come around and have a look.
First thoughts are that the throttle body and idle valve need cleaning.
is the car totally stock or does it have after market stuff like extractors?
- I only think 5.
by warrior » Sat Aug 16, 2014 10:09 am
A crook battery can cause all sorts of problems, anyone wanting a cheap oxy sensor i have one that has done under 1000kms
- I only think 5.
by warrior » Sat Aug 16, 2014 10:12 am
Be very carefull cleaning the throttle body, mazda put a sealer in there against the butterfly and it can be rubbed off very easily. Go on ask me how i know
