I want to find the Bose amp in my 98 roadster. Have fitted a new head unit as the old one was shot, have the back speakers working okay, but can not get the front speakers working. I will probably bypass the amp.
thanks anyone that can help
Bose amp
In the manual for the 1998 models it states
AUDIO AMPLIFIER REMOVAL / INSTALLATION
1. Disconnect the negative battery cable.
2. Remove the dashboard. (refer to 09-17
DASHBOARD REMOVAL/ INSTALLATION.)
3. Remove in the order indicated in the table.
4. Install in the reverse order of removal.
So to get at it you have to remove the dash
Bose amp
Thanks for that Toolbox. Sounds like it will be easier to bypass altogether and find the wire leading to the doors and hook in.
Users browsing this forum: No registered users and 79 guests
