What does new registration cost?
Hi all
I have the opportunity to buy a slightly damaged car with no rego. What is involved in getting a new one, in terms of cost/inspections? I believe the inspections are more rigorous than WOF?
this doesn't list costs involved, but this factsheet explains the reregistering process:
http://www.nzta.govt.nz/resources/facts ... hicle.html
hope that helps
hope that helps
It's a thorough check of a car, much more detailed than a WoF, they check the car for how loud it is (incase you have an aftermarket exhaust) rust etc.
It is pretty common for older cars (90's and older) to fail first time! Check rust around the battery and stuff, a lot of things that would normally slide past a WoF wouldn't pass re-registration.
About 10 years ago I bought a 1990 MR2 that had been off the road in storage for 2.5 years and needed a VIN check.
although the vehicle was in really good condition, the entire process was a complete nightmare and I would personally not go through the expensive drawn out process ever again unless the car was exceptionally special or rare (and even then I would be reluctant)
its totally up to you, but my experience with the process was not pleasant or easy.
Users browsing this forum: Gialee and 18 guests
