James needs help, again. (actual problem)
Post by 4A-GE » Thu Jan 30, 2014 9:25 pm
Today, my right indicator went to the poo factory.
It clicks really fast when it's on, but none of the lights go. Is this a fuse or a relay or both, and where's the one I need to swap out?
NB, left indicator is fine which seems a bit funny.
Post by CordedBowl » Thu Jan 30, 2014 9:39 pm
A sped up indicator normally indicates (hurrrdurrr) that a bulb is out, if none of the lights are flashing but you're sure the bulbs are good then it's probably a fuse or some such.
Did it start straight after your alarm install?
Post by 4A-GE » Fri Jan 31, 2014 11:16 am
Someone else suggested a bulb too.
I figure it can't be a huge problem - The guy who put the thing in is coming back to make sure there aren't any dodgy grounds anywhere.
Started first pop after the install.
Post by 4A-GE » Fri Jan 31, 2014 12:21 pm
Problem solved: Relay wasn't plugged in properly.
Thread closed, everyone out! :lol:
Post by MrGrey » Fri Jan 31, 2014 2:11 pm
Post by 4A-GE » Fri Jan 31, 2014 2:21 pm
Pic dun't work, Herr Grey.
Post by MrGrey » Fri Jan 31, 2014 2:44 pm
sigh, must be host related, its just a borat pic, nothing super duper interesting :wink:
Post by 4A-GE » Fri Jan 31, 2014 3:29 pm
Now it shows.
