Paul, does this mean replacing the standard bias unit with a willwood one at full rear gains you approx 7% more rear bias.... have I read that correctly....??that is actually incorrect the fatory valve is set at 50 percent of the front pressure a willwood valve can be ajusted between 43 and 100 percent of the front pressure so you can infact increase the rear brakeing over factory.
Removing proportioning valve on Master cylinder?
Users browsing this forum: No registered users and 89 guests
