- I only think 5.
by warrior » Tue Oct 15, 2013 3:07 pm
I have just bought a four point roll bar that I will be using for track days etc. I want to put a bit of padding on it do I don't take my head off if it hits it.
Ideas on what to use appox cost and the best place to get it please
by MrGrey » Tue Oct 15, 2013 3:44 pm
2 cheap options just off the top of my head are:
a) pool noodles
b) copper pipe lagging
both are available at your local hardware store
by Keith Jones » Tue Oct 15, 2013 3:53 pm
Para Rubber do a foam tube (bit like noodle material but black).
Comes with different ID hole - 20, 25, 32mm - but with same wall thickness 15mm.
The biggest one won't fit all the way round a roll bar tube, but is much less bulky than the proprietary roll bar padding and much cheaper.
by Furai » Tue Oct 15, 2013 4:15 pm
Cardwells, about $8 a length. Pool noodles wont pass a cert if you go for one.
STIG
by STIG » Tue Oct 15, 2013 5:00 pm
Yeah, I've still got a shitload of that foam padding from Cardwells. It's quite thick stuff - I'd go with a flatter/more compact foam if possible.
R34 GT-R V-spec [STIG]
86' AE86 GT Apex
by SLYDIT » Tue Oct 15, 2013 5:10 pm
theres two thicknesses, one is FIA spec and much thicker, the other isnt as thick but will pass cert/msnz
Users browsing this forum: Gialee and 15 guests
