- I only think 5.
by warrior » Mon Jun 24, 2013 8:26 pm
My wives new car has what I would call a driveline shudder. Firstly I thought it was the clutch but now I,m not so sure.
It only happens at very low revs, 1500-2000 appox and is a bit worse when I am turning a corner compaired to going in a straight line, although it does happen in a straight line also.
I am fairly sure it is not the clutch.
I have another MX5 and it does not do this.
Any ideas where to start to look?
- I only think 5.
Sorry 1992 NA
by SLYDIT » Mon Jun 24, 2013 8:50 pm
engine mounts or diff bushes. exessive play in the diff backlash can cause nasty vibration too.
by brownie » Mon Jun 24, 2013 10:37 pm
Drive shaft universals ,Seem to a common problem with driveline shudder.
Can't say iv'e felt a perfect one yet at work,All seem to have some measure of play,But would be a place to start.
by Timmo » Tue Jun 25, 2013 8:31 am
If you've taken a hit to the driveshaft, this can also cause vibrations
