NA6 Gearbox Drain Plug
Post by GRUVBB » Tue Jun 04, 2013 6:22 am
I want to replace my drain bung at bottom of gearbox as mine is rounded and does not fit socket properly. Are they a standard size so able to grab a cheaper secondhand one from a wrecker off another Mazda. Or do i need to get a certain size and purchase new. I dont have a landline to enable me to ring around pricing. Obviously i want to get it so once oil can is drained it can be replaced straight away. Not much room down below so want to get out quick. Thanks :?:
Post by WideOpenThrottle » Tue Jun 04, 2013 9:02 am
Just grab another either new [if possible off the shelf] or any good 2nd hand one from an MX5 is the only way to be sure but I wouldn't be surprised if most mazda bungs of different models will fit...someone else on the forum might know?
Post by marcellarius » Tue Jun 04, 2013 4:33 pm
I've used these for looking up OE part numbers. While they are for the US models, most should be applicable.
http://www.mazdaspeeddevelopment.com/pa ... apubs.html
The OE part number for a 1990 is 0810-17-122 "Plug, magnet". Sadly doesn't give any clues about the thread etc.
Gearbox bung
Post by GRUVBB » Wed Jun 05, 2013 6:11 pm
Had a job in the city today so was able to call into John Andrew Mazda. Ordered a genuine bung for $15 and the washer is $6. Cheaper than trying to drive around SAVING money..... You gotta spend money to save money. Lucky I did not wreck the fill bung. I could see that it did not fully locate into housing prior to removal.
