Cleaning/painting an engine
Post by Snapfrozen » Wed May 29, 2013 9:51 pm
Hey team,
Currently cleaning/painting my spare long block. Would you paint under where the exhaust and intake gaskets sit or mask it some how? If so how?
I dont have an old gasket as they were farked... :roll:
Post by MrGrey » Wed May 29, 2013 9:57 pm
I am not an expert by any means, but I would paint it all....
I would however make sure to use high temperature engine enamel paint.
I know bunnings sells whiteknight brand engine enamel but I am sure pretty much any paint stockist would have viable alternatives.
Post by Snapfrozen » Wed May 29, 2013 10:04 pm
Using VHT engine enamal...
Also, it's a SNC.. Do I paint around/behind the pullet as best I can or remove it and take my chances?
Post by MrGrey » Wed May 29, 2013 10:18 pm
without seeing it firsthand, I would try painting around it using a cut out cardboard shield to reduce overspray.
I like using the thin rigid cardboard such as used in cereal boxes as opposed to corrugated cardboard which can be trickier to shape.
Painting
Post by GRUVBB » Wed May 29, 2013 10:35 pm
You could smear a bit of oil or Vaseline onto where you do not want the paint to stick and then wipe it clean after paint has cured
Post by chris » Thu May 30, 2013 9:18 am
How have I never thought of that idea ^
Post by Snapfrozen » Thu May 30, 2013 6:50 pm
chris wrote:How have I never thought of that idea ^
Very common, trying easiest first :P
Post by warrior » Thu May 30, 2013 6:56 pm
I have painted an engine in my old rx3 and just put some masking tape over the exhaust/inlet manifold holes then cut around the tape with a razor blade.........done
Post by BRM » Thu May 30, 2013 6:59 pm
/ Wipe off over spray with brake cleaner or prepsol...
