by Timmo » Tue Apr 09, 2013 2:15 pm
When I go over a small, sharp bump (i.e. the fairly smooth speed bump on my street), I hear a small 'knock' from the front of the car (i.e. suspension or steering related)
Any ideas what it is? Sway bar bushing? Top hats?
by chris » Tue Apr 09, 2013 2:24 pm
Have you recently installed new suspension?
by WideOpenThrottle » Tue Apr 09, 2013 5:41 pm
Mines got the same thing and i suspect its the eccentric bolts...one day i will cure it or find its something else!
Mines on the left side only.
by Timmo » Tue Apr 09, 2013 6:51 pm
No, standard suspension (well, standard NB RS suspension which are Bilstein shocks and stiffer rates)
by tomtikki » Tue Apr 09, 2013 9:51 pm
I've got the same type of knock at the front left of mine, I believe it's from the spring shifting.
I keep meaning to pull out the shock and wire the spring in the top & bottom to see if that silences it...
