Aftermarket wing mirrors?
Post by siren676 » Fri Mar 01, 2013 11:15 pm
As some of you may know my wing mirror fell apart at the drifting on sunday.
After looking on trademe for a replacement factory one it looks like it will just be cheaper to replace both with some aftermarket ones.
Anyone used these ones before or know if they'll fit the factory mounts?
http://www.trademe.co.nz/Browse/Listing ... =566843140
Post by dylann » Sat Mar 02, 2013 12:28 am
Reasonably sure the iheartstance car used them, you can always use one of the original mounting points and drill an extra hole if required.
Maybe the middle hole will work? who knows.
I'll be picking the same ones up myself once i have some free cash.
mazline
Post by mazline » Sat Mar 02, 2013 12:52 pm
Ask them what the spacing between the mounting holes are,The ones we used to do would bolt straight on with no mods,Look to be the same spacing.
Need to be 70mm centre to centre
Post by siren676 » Sat Mar 02, 2013 3:16 pm
Just got a reply from the guy and its only 38mm bolt spacing :(
mattapo
Post by mattapo » Sat Mar 02, 2013 7:46 pm
I know Ross at mx5 mart has similar ones that use the mx5 mountings.
Post by siren676 » Sat Mar 02, 2013 8:08 pm
Yeah but they are over twice the price ($140ish inc gst) compared to these ones :lol: and im damn near broke
Post by sprsta » Sat Mar 02, 2013 8:20 pm
just get em and come see me ill make em fit
Post by siren676 » Sat Mar 02, 2013 8:31 pm
Will you use the original mounting points? Dont want to have any visible holes in the doors.
Also this is how my passengers mirror currently sits lol :lol:
Post by sprsta » Sat Mar 02, 2013 8:49 pm
either will have to make a alloy/stainless cover for the holes or have one hole showing
ross
Post by ross » Sat Mar 02, 2013 8:51 pm
They wont fit the standard mirror holes. They look the same as the ones on the white one i got recently.
Post by siren676 » Sat Mar 02, 2013 9:09 pm
sprsta wrote:either will have to make a alloy/stainless cover for the holes or have one hole showing
Sounds good, will put an order in for some large ones tomorrow.
Can you please pm me what you'd charge for fitting them?
ross wrote:They wont fit the standard mirror holes. They look the same as the ones on the white one i got recently.
I understand that since they are only 38mm between the holes.
Just looking back through the iheartstance blog to see how they were mounted on her car
Post by sprsta » Sat Mar 02, 2013 10:11 pm
get the blanking panel
Post by siren676 » Sat Mar 02, 2013 11:26 pm
The $20 thing they offer?
Post by sprsta » Sun Mar 03, 2013 9:11 am
actually not i just read it again you wont need that
Post by Angreal » Mon Mar 04, 2013 2:04 pm
Post by siren676 » Mon Mar 04, 2013 4:03 pm
Too late. Already bought the ones off trademe this morning.
loveitlow
Post by loveitlow » Mon Mar 04, 2013 4:03 pm
I can tell you how she mounted hers if you would like. She redrilled holes to fit the smaller gap on the after market mirror then just used spare screws to fill in the original holes from the standard mirrors (from when I saw it last that was how it was)
Ask Noujan how she mounted hers because when I saw her car on saturday she mounted them to what looked like the original part from standard mirrors which looked really good
NicF
Post by NicF » Mon Mar 04, 2013 5:46 pm
I took my OEM mirrors off, will be replacing them with blanking plates. I'll be putting aftermarket close in ones (S14?) in up by the A pillar ultimately, but for the moment I've got cheapies from Repco there, like this but no remote adjustment.
Mounting on the front window surround was a doddle.
going for something like this
Currently something like this
Post by siren676 » Mon Mar 04, 2013 6:05 pm
Cant say ive ever seen an mx5 with a mirror mounted there, be sure to post up how it goes :D
Post by siren676 » Tue Mar 05, 2013 5:01 pm
Look what arrived this morning :D Only ordered them yesterday, nz post must be getting slightly better :lol:
Turns out that they line up exactly with 1 of the factory screw holes and the random hole in the middle.
Took about 1/2 an hour to get the nut up inside the door to secure the bolt in the middle hole. Finally got it done with a heap of swearing and and using tools in ways they werent designed for :lol:
Just put one of the factory screws in the back hole to stop water getting in.
Both attached. They arent as tall as the factory ones so they will take some getting use to
Post by sprsta » Tue Mar 05, 2013 5:21 pm
NicF wrote:I took my OEM mirrors off, will be replacing them with blanking plates. I'll be putting aftermarket close in ones (S14?) in up by the A pillar ultimately, but for the moment I've got cheapies from Repco there, like this but no remote adjustment.
I made some polycarbonate front quarterglasses so i could drill and mount my mirrors to them like this
the drivers mirror is all good to see out of but the passenger one had the window runner in the way of some of it
not that i really used them much
puddles
Side Mirrors
Post by puddles » Wed Aug 07, 2013 6:40 am
My god putting those side mirrors were so so so hard!
It was insanely hard!
Had to try tighten the nut from inside the door..its sooo small in there!! You just lose the nut cause theres no room in there for your fingers!!
Ive got about 6 nuts in my passenger door lost cause i kept losing them. and you just cant get them out! it gets like a small pocket inside the door where you need to mount the mirror that just gets in the way.
Even talking about it is furiating!!
It took about 2-3 hours just putting them on!!
puddles
side mirrors
Post by puddles » Wed Aug 07, 2013 6:44 am
Oh and i would also like to mention that you can barely see anything out of them! maybe i dont sit up high enough, but they are pretty much useless!!
NicF
Post by NicF » Wed Aug 07, 2013 8:00 am
Easy. Just drive faster than everything else on the road. That way you never have to look behind you.
I like mine, mounted up on the A pillar. You don't have to turn your head so much with them up forward.
Post by Angreal » Wed Aug 07, 2013 10:18 am
NicF wrote:Easy. Just drive faster than everything else on the road. That way you never have to look behind you.
Ah motorbike theory :D
