Window Washer Hoses & Clip Things
Post by Angreal » Thu Feb 28, 2013 10:26 am
Where can I find some window washer hoses and black clip things that the hoses connect into? I've managed to destroy mine and need more to connect them back up to my washer bottle
Post by tomtikki » Thu Feb 28, 2013 3:56 pm
I recently replaced the tube on mine, just got it from Bunnings, the garden section I think... Anyway it was cheap.
There are whole new washer jets on TM for like $12, personally I need a 4mm Y hose connector for mine, not sure where to get that from though as I can only find T connectors - probably a wrecker or eBay and wait a week for it to turn up...
Post by WideOpenThrottle » Thu Feb 28, 2013 4:00 pm
Repco/supercheap have those revolving stands...should have the connectors...tubing as well i think.
Post by Angreal » Thu Feb 28, 2013 4:05 pm
Yeah I need the Y connectors. Mine went all brittle and then shattered
Post by WideOpenThrottle » Thu Feb 28, 2013 4:07 pm
You could go to Waitemata Hydraulics for Brass ones...if you have an arm and a leg to spare! :D
loveitlow
Post by loveitlow » Thu Feb 28, 2013 4:13 pm
I have the same problem and couldnt find that Y peice any where luckily my dad had a spare one from my mums old VW.
I know a lot of people have trouble with him but when all else fails try Ross from Mx5 mart he has tonnes of spare parts and will most likely have one
Post by tomtikki » Thu Feb 28, 2013 4:55 pm
Angreal wrote:Yeah I need the Y connectors. Mine went all brittle and then shattered
Ha! Yeah that what mine did! Suddenly I had no water going to the driverside jet.
Well the ones on Fleabay are $11 shipped (from aus) I'll PM Ross and see what his are.
Rob you want one as well I assume?
Post by SLYDIT » Thu Feb 28, 2013 5:26 pm
I wouldn't say much for them. I got some from pick a part along with a gear of stuff like a heated o20sensor
Toolbox
Post by Toolbox » Thu Feb 28, 2013 9:14 pm
Supercheap Auto's has them, that is where I got mine from. Can't remember price but cheap as.
Post by Angreal » Thu Feb 28, 2013 9:15 pm
Yeah I'm in need of some plus the tubes etc
Post by brownie » Thu Feb 28, 2013 11:58 pm
I'll look into the Y piece tomorrow thru work,See what a new one is worth,They are a problem on all Mazda's
Post by MrGrey » Fri Mar 01, 2013 12:00 am
I work at a Bunnings (Yardsman) and can verify that yes we have suitable fittings. They are actually garden irrigation fittings but they are the same size and cheap.
8)
Post by tomtikki » Fri Mar 01, 2013 1:47 pm
I got 2m (only needed 1.5) of hose from Bunnings for $1.58 -unfortunatly the branch i used didn't have any Y connectors-
Ended up getting one from Repco for $10.
-Ross has em for $7 posted but i couldn't be bothered waiting.
Cleaned & realigned the jets while i was at it, oooh the power!
mazline
Post by mazline » Fri Mar 01, 2013 2:38 pm
Right....
Available from Mazda and us(We are putting a couple into stock),$17.00+gst plus delivery.
Not cheap,for a bit of plastic.
Get them from the States for about $5.00usd.
We are looking to see if we can find a cheaper alternative from Taiwan,
will take a bit of time to find and arrange,would be sent with next shipment we have come over ,IF they make a alternative.
The trick with genuine factory ones is they do clip to the underside of the bonnet,so as to not move around,If that bothers you or not.
A stupid bit of plastic that everyone will need to replace eventually.
Post by Angreal » Fri Mar 01, 2013 2:47 pm
tomtikki wrote:I got 2m (only needed 1.5) of hose from Bunnings for $1.58 -unfortunatly the branch i used didn't have any Y connectors-
Sweet. Looks like I know what I'm doing tomorrow :D
Post by Euen » Sun Mar 03, 2013 1:25 pm
Have a look at the "Nice Products" catalogues here.
http://niceproducts.com.au/catalogues/w ... shpump.php
Davie Holden in Manukau are the agents and generally have good stocks. Their prices weren't too horrendous either.
