Larger injectors
Larger injectors
Post by warrior » Tue Feb 19, 2013 5:43 pm
I have a 1.6 NA with a jackson racing supercharger boosting 6psi, I am ordering the larger crank pulley from TRACKDOG RACING to get it close to 8psi. He told me I will need to upgrade my injectors to 1.8 ones. Does anyone know if they are a direct replacemnet or do they have to be modified in anyway?
Re: Larger injectors
Post by Angreal » Tue Feb 19, 2013 6:26 pm
warrior wrote:I have a 1.6 NA with a jackson racing supercharger boosting 6psi, I am ordering the larger crank pulley from TRACKDOG RACING to get it close to 8psi. He told me I will need to upgrade my injectors to 1.8 ones. Does anyone know if they are a direct replacemnet or do they have to be modified in anyway?
They are a direct replacement. I would advise that you put the fuel rail/injectors on correctly. I had to have 2LOW2C point out how to stop my serious fuel leaks which involves putting the injectors into the rail first, and THEN putting the entire thing back onto the engine. I poked the injectors in and then jammed the rail on top of it which caused me to pinch all the o rings and thus leak lots of petrol :(
Post by sprsta » Tue Feb 19, 2013 7:25 pm
i have some 550cc rx7 ones if you are going to use an aftermarket ecu
Post by warrior » Tue Feb 19, 2013 7:48 pm
It is just running the POWERCARD that comes with the kit so cant go to big with the injectors. It can only add fuel through the revs/powerband not take it away.
Post by punkoutnz » Wed Feb 20, 2013 1:10 pm
I have a set of 360cc ones from a turbo GTX familia otherwise. Make an offer.
Post by SLYDIT » Wed Feb 20, 2013 3:20 pm
You can pull out fuel by changing the clocking crystal in the ecu. You can pull 5 percent or 10 depending on crystal. It will also remove the rev limit
Users browsing this forum: Bing [Bot] and 15 guests
