malcster
by malcster » Thu Feb 07, 2013 5:55 pm
I have had an issue on my nb since running 15s(was an issue with 17s but not as bad) that the rh rear and lh front spring isnt captive compared to other side to get ride height.
went to mag and turbo today to book wheel alignment and aaron there told me if i have the extra fixed ring at the bottom of the shock body and yes i do and apparantly this is where you adjust the ride height from and by adjusting this it will make my spring captive again so if anyone else having the same issue this is what you adjust.
1998 NB MX5 RS TURBO.
